YJ Stalls out HELP! - Page 2 - JeepForum.com
post #16 of 31 Old 04-23-2013, 06:04 AM Thread Starter
ziloh22
Having a bit of the same problem Again but not quite. Now when I pull to a light and sit for a few, she just shuts off. Like she isn't getting fuel or something. I'm going to try taking the throttle body off and giving it a real good cleaning tonight.
2012- Gecko JK Rubicon Unlimited- building...
2007 JK Rubicon Unlimited- 3.5 RK X Factor 37s-SOLD
1995 Gecko YJ with a TJ Front- 35s
ziloh22 is offline
post #17 of 31 Old 04-23-2013, 07:02 AM Thread Starter
ziloh22
Also when jm driving about 25-30 mph she kicks back like it wants to staul.
ziloh22 is offline
post #18 of 31 Old 04-23-2013, 07:10 AM
HaskiE
HaskiE's Avatar
subbed.
do you still have the old intake? was it hard to put on? maybe try swapping back and see if the new parts are the issue?
#theneverendingaxe
HaskiE is offline
post #19 of 31 Old 04-25-2013, 12:01 PM Thread Starter
ziloh22
hmmmm il have to give that a shot maybe this weekend.... for the time being, i took apart the throttle body cleaned it out and the IAC as well... clean as can be now... the jeep hasnt stalled out yet, but i do notice sometimes when sitting idle that it drops to low RPM like it wants to kick off but it doesnt... im going to also change the fuel filter...
ziloh22 is offline
post #20 of 31 Old 04-25-2013, 12:26 PM
mylogylo
I may be way off here. I vaguely remember a while back reading another post where someone had put the manifold gasket on backwards. Can't find it now though. You sure the intake and exhaust manifolds are bolted up good and the gasket is in place correctly? I can't imagine that adding an intake and replacing the exhaust manifold would cause these issues.
mylogylo is offline
post #21 of 31 Old 04-26-2013, 09:49 AM
Que89YJ
Troubleshoot it, dont throw parts at it. First look at codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
As far as it just shutting off, does it instantly go off or does the rpm "fade". Can you keep it running with your foot on the gas? The symptom of the rpm immeadiately going to 0 and dropping out is typical of a bad crank sensor. Check your codes and watch what happens with the rpm when the event happens. The crank sensor gives you the rpm and when it cuts out the rpm will immeadiately drop.
Que89YJ is online now
post #22 of 31 Old 04-26-2013, 10:38 AM
Siva283
Also get that intake vacuum hose hooked back up. It can cause weird stuff to happen with even the smallest line unhook or capped off.
Ask me how I know...
Siva283 is offline
post #23 of 31 Old 04-26-2013, 10:49 AM
pasinbuy
Originally Posted by Mark05059 View Post
just use some starter fluid.. spray around the intake.
Do not use starter fluid to check for vacuum leaks. Too flammable and could cause baldness on face and head.
Use carb cleaner and spray at possible leaks. If idle goes up you have a vacuum leak.
pasinbuy is offline
post #24 of 31 Old 04-26-2013, 11:03 AM
Que89YJ
LOL Awesome Pasinbuy!
post #25 of 31 Old 04-26-2013, 11:16 AM Thread Starter
ziloh22
Man I was just cruising at 25 and it stalled out while I was driving Im at a loss for words lol. I really wanna say my fuel filter or fuel pump because I dont lose power....
ziloh22 is offline
post #26 of 31 Old 04-26-2013, 11:25 AM
Que89YJ
It sounds like your coil or your crank position sensor. Watch the rpm and see if they drop immeadiately. It sounds like a classic CPS.
post #27 of 31 Old 04-26-2013, 11:25 AM Thread Starter
ziloh22
I will replace this and see
ziloh22 is offline
post #28 of 31 Old 04-26-2013, 11:32 AM
Que89YJ
Check your codes first! If the codes say there is something wrong then you always deal with them first, you should always have 12,33,55.
post #29 of 31 Old 04-26-2013, 11:34 AM Thread Starter
ziloh22
How do I check them ? I need an ODB 1 computer no?
ziloh22 is offline
post #30 of 31 Old 04-26-2013, 01:36 PM
Que89YJ
I posted the link in my previous post. Follow the directions in the video.
Fault codes:
Mean Max pics of everything:
No Start:
