YJ Stalls out HELP! - JeepForum.com
post #1 of 31 Old 01-21-2013, 07:34 AM Thread Starter
ziloh22
YJ Stalls out HELP!
i just added a rock it intake, and a new exhaust manifold, and today i was driving to work, and after i try to come a complete stop, i see the RPMS just drop right to 0 and the jeep stalls out... anyone have any ideas? could it be possible that the intake is sucking in too much air? Keeping in mind this is a 95 wrangler with TBI... one thing i have to look into is that one of the breather hoses from the original intake is not connected because i added the new intake and there is not a port for it ( it dumps into the emission canister )
2012- Gecko JK Rubicon Unlimited- building...
2007 JK Rubicon Unlimited- 3.5 RK X Factor 37s-SOLD
1995 Gecko YJ with a TJ Front- 35s
ziloh22 is offline
post #2 of 31 Old 01-21-2013, 11:59 AM
Mark05059
check for vac leaks
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 31 Old 01-21-2013, 12:33 PM Thread Starter
ziloh22
Yea. I looked around and didn't see anything other than the one hose that dumps into the canister. I'm gojng to bolt up the stock intake tonight and see if anything changes.
ziloh22 is offline
post #4 of 31 Old 01-21-2013, 12:36 PM
Mark05059
just use some starter fluid.. spray around the intake.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #5 of 31 Old 01-21-2013, 12:39 PM Thread Starter
ziloh22
I also put on a new belt when I did the exhaust manifold and I had the power steering pump off. Could it be the timing ? Maybe I have to adjust the belt
ziloh22 is offline
post #6 of 31 Old 01-21-2013, 01:14 PM
Mark05059
that belt doesnt control the timing
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #7 of 31 Old 01-21-2013, 01:17 PM Thread Starter
ziloh22
Ok. And I didn't touch the distributor at all either so then it can't be timing. Alright well ill try one thing at a time after work and see. Thanks for chiming in.
ziloh22 is offline
post #8 of 31 Old 01-21-2013, 01:34 PM
fiandjos95
try the idle air control or throttle position sensors
fiandjos95 is offline
post #9 of 31 Old 01-21-2013, 01:39 PM
Mark05059
your jeep was ok before you changed stuff?
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #10 of 31 Old 01-21-2013, 02:12 PM Thread Starter
ziloh22
Yup. Had no issues other than the cracked exhaust manifold. The only other things I changed were the serpentine belt and the intake
ziloh22 is offline
post #11 of 31 Old 01-21-2013, 03:52 PM Thread Starter
ziloh22
Is there an adjustment that should be made or a certain way they should be set ?
ziloh22 is offline
post #12 of 31 Old 01-21-2013, 05:20 PM
fiandjos95
When my jeep had the same problem, i was told by a mechanic i know to just cleaned the idle air control really well and if it doesnt work to change the throttle position sensor and it fixed the problem
post #13 of 31 Old 01-21-2013, 05:55 PM Thread Starter
ziloh22
I'm gojng to try and replace that right now. Running to pep boys. You might make my night!!!
ziloh22 is offline
post #14 of 31 Old 01-21-2013, 06:29 PM
YJ-Nation
Mine was doing that and I have a 93 and it was the alternator. Watch the voltage gauge when it dies. It'll drop if its doing what I think it is.
YJ-Nation is offline
post #15 of 31 Old 01-21-2013, 07:02 PM Thread Starter
ziloh22
That was it!! The throttle position sensor was bad. Now it stays at a steady idle.!!!!!! Thanks man! And to everyone else who helped out.
ziloh22 is offline
