YJ Stalls Alot - JeepForum.com
post #1 of 4 Old 07-16-2001, 12:13 AM Thread Starter
ncmts
YJ Stalls Alot
I rebuilt the carb on my 90 YJ and it stalls even more than before. I have experimented with the idle mixture screws and it runs great at high speeds. But when I put it in gear (automatic) and come to a stoplight, it tends to start running rough and stalls at times. This is in spite of having the idle speed set to about 1000 RPM when out of gear. Anybody know what's going on here? It also stalls alot when going up a hill off-road.
Thanks a bunch,
ncmts
ncmts is offline
post #2 of 4 Old 07-16-2001, 10:03 AM
dartboy
dartboy's Avatar
Did you try replacing the gasket underneath the carb. Mine had the same problems as yours and that fixed it. The gasket was worn too bad and sucking air in around it. Work great when I was driving but when I slowed down or came to a stop it would shuit off on me.
Jason
90 YJ...Stock for now.
74 Dodge Dart Sport
dartboy is offline
post #3 of 4 Old 07-16-2001, 01:48 PM Thread Starter
ncmts
Thanks for the reply.. Yep, I replaced that gasket too. I had to rebuild the carb because the accelator pump was not working. It runs great most of the time but occasionally at idle, in gear it will die. Also on a steep incline if off road.
ncmts
ncmts is offline
post #4 of 4 Old 07-17-2001, 05:54 PM
dartboy
dartboy's Avatar
Did you try any carb or fuel line cleaners...might help.
Jason
74 Dodge Dart Sport
dartboy is offline
TJ Stalls restarts Stalls - Need Help! motobob13 TJ Wrangler Technical Forum 12 09-04-2008 02:45 PM
After doing alot of research... FreakyStyley19 TJ Wrangler Technical Forum 3 08-24-2008 09:49 PM
Just a suggestion that I think someone who knows alot should do... 04WranglerX TJ Wrangler Technical Forum 19 01-03-2007 02:47 PM
ive been hearing alot about this 95YJDAVE YJ Wrangler Technical Forum 3 12-14-2006 10:02 PM
My new OX Locker, I like it alot! :-) MickeSWE TJ Wrangler Technical Forum 9 07-24-2006 01:01 PM
