yj sputters while driving... idles fine... only happens when at operating temp - JeepForum.com
post #1 of 29 Old 07-22-2013, 05:09 PM Thread Starter
mdoddroe
Specs
95 Jeep yj rio grande
2.5L 4cyl
80K miles
Auto Trans
Jeep sputters when driving... Occurs mostly at cruising speeds 40-65 mph but after engine is warm it occurs at all speeds. Doesn't occur in neutral, just when i'm giving it gas. Doesn't happen when engine is cold, so when I first get up it drives fine. This only occurs when engine is warm and it's intermittent. No codes at all other than defaults. Feels like it's not getting a constant stream of gas and it loses power going uphill.
What I've already replaced:
O2 sensor
Spark plugs
Coolant temp sensor
Fuel filter
Any suggestions?
I have a hint it's the fuel pump but just wanted to change out these cheap ones first
mdoddroe is offline
post #2 of 29 Old 07-22-2013, 05:35 PM
bigbossd1030
Originally Posted by mdoddroe
Specs
2.5L 4cyl
80K miles
Auto Trans
O2 sensor
Spark plugs
Coolant temp sensor
Fuel filter
Any suggestions?
TPS? Mine would do something similar, didn't need a hill to loose the power on though. I found if I shut it off then back on it would be fine for about another 20 mins, but would happen again. The cel didn't come on for this for a good week or so. Then it came on so I ran the codes, got a 24 iirc. I am thinking that if it was the fuel pump, wouldn't it do it all the time, like regardless of temp???
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 29 Old 07-22-2013, 07:20 PM
clush
Mine had similar symptoms and a new fuel pump fixed it
clush is offline
post #4 of 29 Old 07-22-2013, 07:24 PM Thread Starter
mdoddroe
Yea that's what i'm leaving toward. I'm going to get the pressure tested in the fuel lines then ill go from there. Got a sending unit and pump for $140.
mdoddroe is offline
post #5 of 29 Old 07-22-2013, 09:40 PM
zombiechief
A dirty fuel filter will do that too. At idle it doesn't have the fuel demand like it does under a load so it would get enough thru the filter. As soon as you're on the gas, the filter can't keep up so it starts to cut out. I'd change that first since it's only about 10 bux vs 140.
Treat every situation like a dog. If you can't eat it or play with it pee on it and walk away.
zombiechief is offline
post #6 of 29 Old 07-23-2013, 05:21 AM
vadslram
sputters is kind of vague. It could be misfiring from ignition crossfire. Warmed up and under a little load crossfire would feel like a stutter.
Other than that I have no help.
vadslram is offline
post #7 of 29 Old 07-23-2013, 02:14 PM
ladderslug
Originally Posted by mdoddroe View Post
Specs
2.5L 4cyl
80K miles
Auto Trans
O2 sensor
Spark plugs
Coolant temp sensor
Fuel filter
Any suggestions?
I have the same problem. I have changed the alternator, fuel filter, 02 sensor, and the person I bought it from changed the fuel filter but it whines load as a power steering pump that is low on fluid.
Mine also will not do it when not at temp. A mechanic friend said to take off the disconnect on my cables and clean them off to look like new, drive it to make sure no electrical deveations and if still does it replace the fuel pump and fuel filter ( even though I just replaced it), he also said to replace the sending unit for the gauge, mine is a 1/4 tank off.
ladderslug is offline
post #8 of 29 Old 07-23-2013, 02:23 PM
ladderslug
Specs
2.5L 4cyl
80K miles
Auto Trans
O2 sensor
Spark plugs
Coolant temp sensor
Fuel filter
Any suggestions?
post #9 of 29 Old 07-23-2013, 02:34 PM
ladderslug
I was told the fuel pump will heat up and can change and loose presure
post #10 of 29 Old 07-23-2013, 03:21 PM
bigbossd1030
Ah that makes some sense.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #11 of 29 Old 07-23-2013, 03:31 PM
g_oneill
I have the occasional what my wife calls "putt-putt". Loss of power at different speeds on my 2.5. The problem goes away when I wiggle the wire on the 3rd injector. The problem was worst when I was driving long distances for a few hours straight and all the vibration that come along with 70 MPH. It came back a few times until I cleaned all the connections. That was one of the best cheapest fixes I ever did. Can't hurt to clean those connections. It has not come back all summer long, fingers crossed.
g_oneill is offline
post #12 of 29 Old 07-23-2013, 09:34 PM
slamb
I had a similar problem on my '91 4.0. It was a bad catalytic converter. Once I replaced that, now runs like new.
slamb is offline
post #13 of 29 Old 07-24-2013, 05:26 AM
vadslram
Isn't it an electric pump? they are cooled by the fuel flowing through them.
vadslram is offline
post #14 of 29 Old 07-24-2013, 07:10 AM
clush
Electrical parts tend to break down when they get hot if they are going bad. Pumps coils or whatever it may be
clush is offline
post #15 of 29 Old 07-24-2013, 02:21 PM
FiremanDrew
I just recently purchased my jeep and I was having the same problem. It turned out to be the fuel pump. I recommend replacing it.
FiremanDrew is offline
