Yj sputters than dies help plz!! - JeepForum.com
post #1 of 2 Old 03-28-2013, 07:10 AM Thread Starter
Snakebite22
How's it going I have a 95 yj 2.5 just recently changed my water pump due to it was leaking put new manifold gasket put everything back on correctly an tried Turing her on she ran for a bit did a road test lost rpm an started bobbing an died tries starting up again an rough idle tries giving her some gas an she died again had to get her towed back home she'll start for a sec or 2 an just die I changed the tps, map, new wires an spark plugs the fuel rail was a little loose so wondering if a little water got inside also got a new battery please help thanks.
Snakebite22 is offline
post #2 of 2 Old 03-28-2013, 09:14 AM
Que89YJ
If the rpm's dropped and then it is the crank position sensor. The pickup in the distributor is possible. Always start by checking your fault codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
