yj sputtering.. again! - JeepForum.com
post #1 of 21 Old 05-14-2011, 02:46 PM Thread Starter
stcarter44
i posted earlier about my yj sputtering its a 4 banger 4 inch lift 33 inch mud king tires. it was sputtering before and i ended up doing a new fuel pump a fuel regulator, fuel filter, plugs cap router and the tps and when i did that it stopped sputtering. untill about 3 days ago and its back again. it only sputters in 3rd 4th and 5th gear and not as much in 5th. its pretty bad in 4th gear it only sputters when i step on the gas. as soon as i take my foot off the gas it stops.. any ideas?
also it only happened once but when i started the car in a parking lot the rpms were kinda high around 1200 rpms but when i turned it off and turned it back on they were normal
stcarter44 is offline
post #2 of 21 Old 05-15-2011, 08:32 PM Thread Starter
stcarter44
anyone??!?!?!?!?
post #3 of 21 Old 05-16-2011, 10:33 AM
jaxtell
Mine as doing that and I had a vacuum leak on the vacuum line to the fuel pressure regulator, dry rot.
jaxtell is offline
post #4 of 21 Old 05-16-2011, 02:29 PM
Tblair23221
Might try removing and cleaning the throttle body and IAC. Just takes a few mins and 5 bucks for cleaner and a new gasket. Sounds like you already have checked the fuel pressure but if not it might be worth it.
Tblair23221 is offline
post #5 of 21 Old 05-17-2011, 08:30 AM Thread Starter
stcarter44
i have checked fuel pressure. before doing the pump and regulator i had bad pressure at around 22 psi's. when i did it i went up to about 27 28 psi's wich is still not what i heard was normal. i heard around 31 was normal. it really only sputters when is been driving for like 10 minutes. if it has been sitting for a a while like over night or while im at work or at school and i go to drive it it runs fine for the first 10 minuites or so but than it starts to sputter
i will look into a vaccum line though
post #6 of 21 Old 05-17-2011, 11:26 AM
Buddha
Yeah, pull that vacuum line off the fuel pressure regulator and the fuel pressure at the rail should go up 8 psi or so. If it doesn't you have a vacuum leak somewhere.
Assuming you didn't do all the things listed in your original post at the same time, what was the last thing you did? If it was the TPS, I have read on here where those can be bad right out of the box. The fact that the sputtering stops when you let off the gas could point to the TPS... It's easy to change out so it might be worth taking it back and trying another one.
Keep us posted.
I have read hundreds, if not thousands, of threads on here and it's amazing the percentage of problems that wind up being caused by something the owner has accidentally done to the Jeep while working on it.
Moral to the story: If you moved it, unscrewed it, unbolted it, hammered on it, wiped it off, re-wired or replaced it - Check there first!
Buddha is offline
post #7 of 21 Old 05-17-2011, 02:31 PM
RockShoxTora
Seafoam. Mine did the exact same thing.
Before I decided to invest in any parts, I just bought some seafoam. Poured half the bottle through the air intake and the rest in the gas tank. Problem solved.
It's worth a shot and it's pretty cheap.
1995 YJ
-3.5" Black Diamond Suspension Lift, Skyjacker Hydro 7000s
-1.25" Body Lift
-Trail-Gear Bumper and Tire Swing-Out
-31" BFG M/Ts KM
Square Headlights Member #751
RockShoxTora is offline
post #8 of 21 Old 05-17-2011, 02:38 PM
Andywear
Air intake? Whoa!
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #9 of 21 Old 05-17-2011, 03:15 PM
bigbossd1030
Originally Posted by Andywear View Post
Air intake? Whoa!
Why in the hell did you put it in the dai intake?!
Correct me if Im wrong but I just did mine three days ago and I kinda remember the bottle saying gas tank, Crankcase and brake booster line.
I don't remember anything about the air intake being an option.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #10 of 21 Old 05-17-2011, 06:52 PM Thread Starter
stcarter44
just wondering what the IAC is? and the vaccum lines didnt look bad just looking at them i will try disconnecting them tmr.. and what exactly is seafoam ive never heard of that
post #11 of 21 Old 05-17-2011, 06:53 PM Thread Starter
stcarter44
anyone think it could be a bad temp sensor???
post #12 of 21 Old 05-17-2011, 07:05 PM
goAF
air intake + sea foam must have been a typo. Sea foam scares me.
goAF is offline
post #13 of 21 Old 05-17-2011, 07:51 PM
Buddha
Idle air controller. Controls the amount of air your engine gets at idle
Sent from my iPhone using JeepForum (and my thumbs)
Buddha is offline
post #14 of 21 Old 05-17-2011, 07:55 PM
Buddha
SeaFoam is a very good gasoline additive that stabilizes fuel and cleans fuel systems. You can pour it into the air intake manifold with the engine running and it will help clean it. Having said that, cleaning the air intake manifold is easy to do and there are good write-ups on this site describing how it's done.
Buddha is offline
post #15 of 21 Old 05-17-2011, 08:24 PM Thread Starter
stcarter44
where would i buy seafoam?
Sputtering 2.5L masterodisaster TJ Wrangler Technical Forum 4 05-11-2010 03:31 PM
sputtering at take off BennyV TJ Wrangler Technical Forum 19 02-10-2010 10:05 PM
sputtering and wants to die GRN_BEAST95 YJ Wrangler Technical Forum 8 06-17-2009 04:55 PM
Need help, sputtering TJ hazade TJ Wrangler Technical Forum 11 08-27-2007 11:38 AM
2.5 sputtering randy33876 YJ Wrangler Technical Forum 25 02-05-2005 09:44 AM
