Yj sputtering - JeepForum.com
post #1 of 11 Old 10-16-2011, 05:04 PM Thread Starter
josholson89
Yj sputtering
So a few months ago I replaced the clutch, slave cylinder, spark plugs, dist cap and rotor, and plug wires. Ever since that I have been having a litle bit of sputtering that causes the engine to "knock" a little bit until I ease off the gas then its fine. I readjusted the gap in my plugs and that helped a little bit. It seems like there is either too much or too little fuel in the cylinder and thats what is causing the sputtering. I replaced the throttle positioning sensor and fuel filter and its still doing it. Also the check engine light came on but no one is able to read the code. Any help will be appreciated.
92 Yj 4.0 5 speed
3" lift
33x12.50 MT's
josholson89 is offline
post #2 of 11 Old 10-16-2011, 05:11 PM Thread Starter
josholson89
I am about to sell this YJ and I am just trying to work out this little sputtering so it will sell a little easier.
post #3 of 11 Old 10-16-2011, 08:14 PM
coleslaw
1987 YJ Wrangler
Did you put platnum plugs in it? I put them in mine and it spit and sputtered. Put the AC plugs in and it purred like a kitten.
Coleslaw
A country that tries to spend itself to prosperity is like a man standing in a bucket and trying to lift himself by the handles.
Winston Churchill
87 YJ I6, nuttered and rushed, 2.5" lift, 31x10.5, custom made f&r bumpers, Mojave heater, TJ flares, Superwinch S9000, hm swingout tire carrier, tool drawer, custom electical control, and more in the works...........
coleslaw is offline
post #4 of 11 Old 10-20-2011, 07:24 PM Thread Starter
josholson89
Well I gave that a shot and it kept sputtering. I have it in the shop right now for a diagnostic so once I find out what it was ill post it up here.
post #5 of 11 Old 10-20-2011, 08:48 PM
oldtime_ironman
Strange that nobody could read the codes. It's pretty easy to do, no scanner required. Just use the key trick. Offhand guessing here because I don't know more about your problems. I'd bet on either the fuel pressure is marginal, or the O2 sensor. When does the suttering occur? Hot or cold? At a certain RPM? Idle or when you nail it?
oldtime_ironman is offline
post #6 of 11 Old 10-20-2011, 11:20 PM
ptwhaler
^ x2.. I spent over $300 replacing every sensor and filter I could along with new coil, plugs, wires etc. Learned how to do the key trick from this site and found out it was my ECM causing it to sputter over 2600rpm. Being running great since I replaced that.
"In wine there is truth
In beer there is strength
In water there is bacteria"
ptwhaler is offline
post #7 of 11 Old 10-21-2011, 06:05 PM Thread Starter
josholson89
Well the shop said it was a faulty throttle position sensor which i replaced brand new a couple weeks ago because i thought it would fix the problem. apparently the part i got from schucks was bad.
post #8 of 11 Old 10-21-2011, 08:45 PM Thread Starter
josholson89
I forgot how to do the key trick. Its been a long time since i've had to do it. How do you do it?
post #9 of 11 Old 10-21-2011, 11:04 PM
ptwhaler
You just turn the key on and off, I think it's 3 times, leaving it on the 3rd time. Then you count the flashes of the CEL to get the codes. There are several good write ups on here with a list of what each code means. Probably in the FAQ's.
ptwhaler is offline
post #10 of 11 Old 10-22-2011, 02:10 AM
oldtime_ironman
Here's a short vidoe of the key trick. It's one of the first things I do whenever something's acting up. Let us know what you find out! Also, you can clear all the codes and re-set the computer by simply disconnecting the battery for a few minutes. Basically re-boot it into a clean state. It's a good idea to do this after anythime you work on the engine. Chances are very good that you will see codes 12, 33, and 55 - this is normal. Hope that helps!
post #11 of 11 Old 10-24-2011, 09:19 PM Thread Starter
josholson89
Well I got it back from the shop today. Turns out all it was was that TPS. The one I got from Orielly was defective but its got a new one in it now and its running very strong! thanks for all the help and hopefully someone else gets some use out of this and avoids the shop like i had to do.
yj sputtering.. again! stcarter44 YJ Wrangler Technical Forum 20 06-09-2011 07:45 PM
sputtering zullo YJ Wrangler Technical Forum 3 05-17-2011 07:35 AM
yj sputtering stcarter44 YJ Wrangler Technical Forum 6 04-28-2011 08:08 PM
Sputtering 2.5L masterodisaster TJ Wrangler Technical Forum 4 05-11-2010 03:31 PM
Sputtering '98' TJ chobes TJ Wrangler Technical Forum 8 01-18-2006 10:49 AM
