Yj spitting and sputtering with black soot - JeepForum.com
post #1 of 26 Old 02-17-2017, 08:44 AM Thread Starter
way2fastmike
1973 CJ5
okay this going to be long but maybe someone can help. back in oct during the hurricane (Matthew) my daughter called me stranded beside the road, got there the jeep seemed to be out of fuel, would start right up but shut down. i put fuel in it and got it started, dont think it was out of gas, but was acting like it. got the jeep home running it in third gear keeping the rpm up. took it to a repair man. he keep it two weeks, replaced the intake gasket,replaced some vaccum lines he said was question. said it was leaking. also the valve cover gasket. said he checked out the fuel pump, regulator and no problem, had good pressure. said the tps was good also. called me to come get it as he cant fix it. didn't have a machine to run codes. picked it up and took home. run sea foam in the fuel.
no help. still act like it was starving for fuel. took to another repair shop. kept it a week. replaced battery, injector, and fuel pump, new plugs and the i.s.a. motor. helped a little but still not right. still sputtering a little and sometime wants to die and cut off at stop lights, now its using double the fuel it did before and im getting black soot out the back onto the ground. so i got it home and decided to change some parts my self. i installed new, air filter, M.A.P. SENSOR, C.P.S, T.P.S., I ALSO CHECKED OUT THE PCV and it is sucking good and when off i can hear the rattle in it so it seems to be okay. guys im at the ropes end hanging on.thanks for all the commits to now and in the days to come.
I ALSO JUST TOOK OUT THE PLUGS I JUST INSTALLED LESS THAN A MONTH AGO AND THEY ARE ALL SOOTY NOW.
IT A 1988 WRANGLER 2.5 RENIX 4CYL, 5 SPEED TRANS
way2fastmike is offline
post #2 of 26 Old 02-17-2017, 08:59 AM Thread Starter
way2fastmike
1973 CJ5
post #3 of 26 Old 02-17-2017, 09:38 AM
Dake
Dake's Avatar
Is your O2 sensor good . My wires got ripped out on the trail and had the same symptoms.
Waiting on my Rough Country lift to sag!
Dake is online now
post #4 of 26 Old 02-17-2017, 09:50 AM
Que89YJ
The renix is a different sort of critter when it comes to replacing sensors. Do you have a multimeter and do you know how to use it?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 26 Old 02-17-2017, 11:16 AM
Dake
Dake's Avatar
After you changed the sensors did you unplug the battery so the computer can reset. I think you need to unplug the battery for 30 minutes I'm not real sure on how long.
Dake is online now
post #6 of 26 Old 02-17-2017, 02:48 PM
Que89YJ
That renix is a different animal. You need to adjust some sensors like the TPS after you replace them.
Fault codes:
No Start:
Que89YJ is offline
post #7 of 26 Old 02-18-2017, 06:27 AM
yjmike82
First never go to that mechanic again, you don't need a machine to check codes on these you just turn the key and count the flashes. I'd start there and see what codes you have
As said before O2 sensor, also check plug wires and your coil.
I had the wire between the coil and distributer fry and it would work perfectly until the Jeep got warm, then it would shut down. I tend to lean towards ignition issues.
yjmike82 is offline
post #8 of 26 Old 02-18-2017, 07:22 AM
Que89YJ
The renix system on the 87/90 doesn't work like the 91/95 for fault codes.
The rest is true. You need a meter and know how to use it to setup the TPS, wot, and isa when replaced. O2 is a good call.
Fault codes:
No Start:
Que89YJ is offline
post #9 of 26 Old 02-18-2017, 08:32 AM
yjmike82
Good to know I figured all YJs used OBDI codes, maybe the dealer than for getting the codes checked.
yjmike82 is offline
post #10 of 26 Old 02-18-2017, 04:22 PM Thread Starter
way2fastmike
1973 CJ5
THE 02 SENSOR IS NEW, also today i changed out the coolant temp sensor, the egr valve. cleaned the tb with tb spray. still same issue. called the dealer, was told they dont even have a Manuel for this jeep. said they dont even know if the machine they have could read any codes at all. im lost guys.
post #11 of 26 Old 02-18-2017, 04:26 PM Thread Starter
way2fastmike
1973 CJ5
all parts that have been replaced,
tps
cps
02 sensor
intake gasket
valve cover gasket
fuel filter
fuel pump
map
ics
battery
injector
egr
cts
i dont knpow what else to do.
plug in the tps and the jeep runs bad, unplug the tps and it smooths out and runs good. crazy
post #12 of 26 Old 02-18-2017, 08:11 PM
Que89YJ
I have a PDF of the factory manual. I will send you the link to my Dropbox. Do you have a meter and know how to use it?
Fault codes:
No Start:
Que89YJ is offline
post #13 of 26 Old 02-18-2017, 08:30 PM
Labhound
Hmmm, sounds like what mine is doing now, I'll have to keep a watch on this before I start throwing parts at it.
Labhound is offline
post #14 of 26 Old 02-19-2017, 07:33 AM
Que89YJ
tps
cps
02 sensor
intake gasket
valve cover gasket
fuel filter
fuel pump
map
ics
battery
injector
egr
cts
You need to adjust it. I sent you the link for the service manual. Follow the directions. You can't just swap a sensor on our TBI system. It requires the range to be set. If you have it running good without the TPS you are really close.
Fault codes:
No Start:
Que89YJ is offline
post #15 of 26 Old 02-20-2017, 04:58 PM Thread Starter
way2fastmike
1973 CJ5
TO THE LAST POST, i did set the tps after install but after reading it again i may need to redue it. i think with i tested it i didnt make sure the isa arm was not touching the throttle. my reading at rest was 1.2 maybe and from what i read it needed to be at 0.9 something. yes i have a multi meter and know a little about it. lol sorry im learning.
