yj speedo - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > yj speedo
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!
Unread 04-12-2015, 12:54 AM   #1
doconnell96
yj speedo
for the last 6 months my speedo has stopped working when it rains. after it stopped raining everything would go back to normal but this past rainstorm it stopped working and hasnt started again. my tach and lights still work and i have no idea whats wrong
doconnell96 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 01:25 AM   #2
doconnell96
and i apologize if this has already been talked about before i have searched for a couple days now
Unread 04-13-2015, 09:35 AM   #3
Que89YJ
On the side of the tcase is a sensor. You need to check the sensor by removing it from the side of the tcase and put a drill motor on the sensor where the gear sits. With the key on see if you register a speed reading on the cluster.
http://www.jeepforum.com/forum/f12/n...nding-2655234/
Que89YJ is offline   Reply With Quote Quick reply to this message
