YJ spark issue???? - JeepForum.com
post #1 of 9 Old 03-12-2014, 03:57 PM Thread Starter
JoshsYJ
YJ spark issue????
Today I went to start my 94 YJ with the 4.0 and shortly after starting the check engine light came on. After driving for 10 minutes she started to hesitate and stumble. The longer I drove the worse it got. I pulled into my driveway and shut her off. I then tried to restart the Jeep and she would crank but wouldn't start. I checked for what code was showing and only had the normal 12, 33, and 55. After letting the Jeep sit for 15 minutes I went back outside and tried restarting. When I turned the keyed nothing happened. I still had power to all accessories though. I tried turning they key several times and finally the starter turned over and the engine stated right up and the engine light was no longer on. What is going on??? Also, I replaced the crank position sensor a month ago. How can the check engine light come on but not store codes?
United States Marine Corps- Doing Gods work since 1775.
JoshsYJ is offline
post #2 of 9 Old 03-12-2014, 04:09 PM
Mark05059
clean your battery terminals
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 9 Old 03-12-2014, 04:38 PM Thread Starter
JoshsYJ
They are clean and have newer clamps that fit tightly.
JoshsYJ is offline
post #4 of 9 Old 03-12-2014, 05:24 PM
Why J?
Why J?'s Avatar
Are the wires clean at both ends?
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #5 of 9 Old 03-12-2014, 05:27 PM Thread Starter
JoshsYJ
That I am unsure of but would that cause the engine stumble and barely run. I understand that it could cause the no power to the starter issue.
JoshsYJ is offline
post #6 of 9 Old 03-13-2014, 04:16 AM
Mark05059
your fuel injection uses power to run.. Your alternator code (41) is saying there is something wrong with the wiring or the alternator. The stumbling at the same time points to a wiring problem.. usually the battery terminals.. clean both ends... check to see if there is a bunch of crud inside the jacket also. If there is then change the cables...
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #7 of 9 Old 03-13-2014, 02:09 PM Thread Starter
JoshsYJ
Problem solved! The positive terminal somehow got dirt and grim between it and the cable end. I cleaned it and it was good as new. Thanks the responses guys.
JoshsYJ is offline
post #8 of 9 Old 03-13-2014, 05:18 PM
Mark05059
Glad you got it fixed. Amazing...
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #9 of 9 Old 03-13-2014, 08:30 PM
Que89YJ
Great call Mark.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
jeep no start
