Yj Soft Uppers... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yj Soft Uppers...
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-22-2014, 09:31 PM   #1
poppatello
Yj Soft Uppers...
I bought and installed an early Yj OEM style soft top that is a Bestop. I got soft doors with it but the uppers aren't the correct ones. I went to take a picture this evening to post up for sale a realized I have the correct uppers without the metal inserts. The correct uppers are Velcro, but the original are sowed. What do I do here? Cut the old other one off and velcro the correct one on? Seems like it would but I don't want to destroy them. Also, the metal rod is curved at the top on the current upper. Do I need the correct metal rods for the square upper corner???
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline   Reply With Quote
Unread 04-22-2014, 09:37 PM   #2
poppatello
I couldn't add pictures as the size are too big. Here is a link to another post on my club site with pictures...
http://www.njjeep.org/phpbb/viewtopic.php?f=21&t=22774
Paved Roads
Unread 04-22-2014, 10:04 PM   #3
jaycal3
Link needs a login to access.... use photobucket or something else to add the pics...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms
KCCO
jaycal3 is offline   Reply With Quote
Unread 04-22-2014, 10:11 PM   #4
whiteyj1994
you need the correct metal frame. then you use the velcro to attach the skin. BTW I had to sign up for NJJA to see your pictures.
lead foot locker and away we go
whiteyj1994 is online now   Reply With Quote
Unread 04-22-2014, 10:25 PM   #5
stenyeart
stenyeart's Avatar
X2
The uppers with the frame (rounded corner) are Supertop style. The replacements that came with your top are OEM style. You either need to buy OEM style frames or return the top and get the supertop.
stenyeart is offline   Reply With Quote
Unread 04-22-2014, 10:56 PM   #6
poppatello
Ok, that's what I thought. Thank you...
Paved Roads
