Yj small block rams horn manifold flange? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Yj small block rams horn manifold flange?
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-22-2014, 12:33 PM   #1
87TPIYJ
1987 YJ Wrangler
Im having to change my true duel exhaust to cross over under the oil pan. Im doing it myself so I can route it where I want and have mandril bends. I bought a set of old Corvette Rams horn 2.5" center dumps. The manifolds came with an exhaust donut. So for you guys that used rams horn manifolds on your SBC swap. What type of pipe flange do you use on the manifold?
Is it normal like this
http://www.summitracing.com/parts/hed-21105/overview/
Ball and socket like this?
http://www.summitracing.com/parts/hed-21123/overview/
Or something else?
87 YJ, 350 TPI, NV3500, NP241C, 35x12.50x17, SOA, Warn 9.5XP Build thread: IROCk
87TPIYJ is offline   Reply With Quote
Unread Yesterday, 05:01 AM   #2
87TPIYJ
1987 YJ Wrangler
Must be a good question.
Unread Yesterday, 05:05 AM   #3
superj
1987 YJ Wrangler
The rams horn are from the older engines so I bet it uses the regular style. I bought a set of those for my 79 GMC step side with stock 350, back in the day. I never put them on though
Slow ride, take it easy
superj is online now   Reply With Quote
Unread Yesterday, 09:33 AM   #4
87TPIYJ
1987 YJ Wrangler
I think I found the answer: Corvette Flat Exhaust Pipe Flange (1962-74). According to the vendor this should work so I ordered 2.
http://corvettespecialty.com/corvett...flange-1962-74
Unread Yesterday, 11:07 AM   #5
Galligher
Don't you need the pipe sleeve for the flanges? I am installing a 330hp crate engine with those ram horns. I am not as concerned with perfectly smooth bends so I am looking at making y -pipe work. Just trying to find one with 2 1/2 inlets and 3" outlets. Good luck!
1995 4Cyl Wrangler - Used to having modified Mustangs, I have to get this thing more guts!
Galligher is offline   Reply With Quote
Unread Yesterday, 11:18 AM   #6
87TPIYJ
1987 YJ Wrangler
I asked about the pipe sleeve. He said that i could just slide the sleeve down the pipe a little farther and use the pipe as the sleeve. We will see if that holds true if not then it will be these.
http://corvettespecialty.com/corvett...sleeve-1953-82
Unread Yesterday, 03:26 PM   #7
Galligher
Let us know how it works. I am not really sure how it will tighten if the flange slips over the pipe? Unless the pipes you are using already have a "lip" for the donut/flange.
Unread Yesterday, 04:46 PM   #8
87TPIYJ
1987 YJ Wrangler
The ID of the donut is 2.524, so that it will slip over the pipe. The flange I ordered has a bevel that should fit the donut. The flange will be welded to the pipe. See what I'm saying?
Sent from AutoGuide.com Free App
Unread Today, 10:45 AM   #9
Galligher
Ok, I missed the flange part.
