Quantcast YJ slips out of 4wd - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ slips out of 4wd
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 02-03-2002, 03:45 PM   #1
bobznew
YJ slips out of 4wd
First of all, it's difficult to shift the t-case into 4wd. When it finally shifts into 4wd, it will often slip out. I know it's not a vacuum problem, b/c I have a posi-lok.
Will a stretched chain cause it to slip out of 4wd? If not, could someone please give me some advice here??
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline   Reply With Quote
Old 02-04-2002, 11:05 AM   #2
osburn
Never heard of anyone having that problem with the 231. I used to have that problem with an Isuzu Trooper I had so I tied the lever back. Sorry, I realize that isn't much help. I just ain't sure what the problem might be. I doubt it's the chain though. More likely a shift detent problem in your 231. Get a manual and tear it open. It's not really too bad a job if you have a decent shop to work in. A puller and a few varieties of snap ring pliers are a real plus. It's been awhile since I've pulled one of these apart so I'm sorry I can't produce any sort of detailed help. The case is simple though (with a shop manual) and I'm sure if you get it open the problem will be apparent.
Matt Osburn
Greengo
Rigrater Score 1032
osburn is offline   Reply With Quote
Old 02-04-2002, 09:56 PM   #3
bob91yj
I'd definitely take a look at the linkage. Does either 4wd range work? Are you getting a false neutral in 4wd or does the rear axle still work? Is the front d-shaft turning when you move forward? If so, it may be a bad vacuum motor, or hoses disconnected. You don't show a body lift in your signature, but they can cause problems with getting into 4-lo.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline   Reply With Quote
Old 02-05-2002, 02:41 PM   #4
bobznew
The problem is with both ranges. As a matter of fact, I CAN get the gear reduction with 4lo, but neither of the front tires have power, as the front d-shaft does not turn.
I know the problem is not with the vac hoses, because I've got a posi-lok, and it works great.
If I have a successfull gear reduction with 4lo, but have no front d-shaft power, what could be the problem?
BTW, no body lift; only suspension.
Thanks for the help guys.
Glock Forum
