YJ shaking while accelrating - JeepForum.com
post #1 of 8 Old 04-01-2010, 05:01 PM Thread Starter
jerzeygrinch
Today my stock 92 YJ started shaking bad, like I was driving over rumble strips while accelrating in 2nd, 3rd, 4th gear. Never got to 5th because I didint want to go any faster. Any ideas whats going on?
jerzeygrinch is offline
post #2 of 8 Old 04-01-2010, 05:11 PM
jay-h
U-joints or motor/transmission mounts
jay-h is offline
post #3 of 8 Old 04-01-2010, 05:50 PM
cbmadcow
cbmadcow's Avatar
Check the u-joints.
I just replace my rear u-joint this past weekend. Exact same symptom driving down the highway feeling this very nasty vibration starting at about 50mph. It's an easy repair as long as the u-joints come out easy.
Kevin
1993 Jeep Wrangler lifted YJ
Previous Jeep 1998 TJ
cbmadcow is offline
post #4 of 8 Old 04-01-2010, 07:39 PM
jaminb
also check the play of the slip yoke ( the output of the t case). if it moves around this will more likely be the cause of your vibration than u joints. You joints would not vibrate that bad through all those gears, they would eventually reach a point where they would even off.
jaminb is offline
post #5 of 8 Old 04-02-2010, 07:55 PM Thread Starter
jerzeygrinch
I was told it was the yoke in the pumpkin rear end that was bad but I dont believe them. He showed me the inside and as the wheel was turned the piece in the middle he called the yoke spit some oil out as it turned and this was the problem?? Also said the rear end needed to be rebuilt!! Gonna tell them to put it back together and I'll limp it home and look for other opinions. Thoughts???
post #6 of 8 Old 04-02-2010, 08:31 PM
fallenbirdbeak
It's the U-joints. I doubt it is the motor mounts, but you never know. Check the U-joints first.
This happened to mine before they broke and my rear drive shaft was hanging from the rear of my Jeep like a damn ****.
My 4wd did not work at the time, so I had to get towed like a btch.
My Jeep doesn't get me laid, but who cares.
My goal in life is to be able to work on cars like Tony Starks from Iron Man.
fallenbirdbeak is offline
post #7 of 8 Old 04-02-2010, 10:05 PM
jaminb
It is possible that they input yoke on the rear differential is bad and moving around causing your vibrations. But checks these in order first...
1. U joints. ( move the drive shaft around by hand and see if you can see the joints moving)
2. Check for play in the slip yoke. ( it should NOT be able to move up and down noticably)
3. Check your motor mounts and trans mission mount as well at the torque pin. ( torque pin is the little nipple looking thing that sticks out from under the t case skid plate)
jaminb is offline
post #8 of 8 Old 04-02-2010, 10:31 PM
MJMPC
Check your air pressure in your tires and then rotate them. Had a truck do that once.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
Hand throttle help accelrating when shifting` wes19d TJ Wrangler Technical Forum 9 04-19-2009 07:09 PM
The Shaking RedWind YJ Wrangler Technical Forum 12 02-26-2009 10:51 AM
Odd Shaking panathinaikos55 TJ Wrangler Technical Forum 8 02-23-2009 08:21 AM
Still got that shaking 4x4Hawaii YJ Wrangler Technical Forum 3 10-15-2008 08:17 PM
shaking jdeluc12 TJ Wrangler Technical Forum 4 02-15-2007 11:16 AM
