YJ shackle install... - JeepForum.com
post #1 of 4 Old 10-21-2002, 01:22 PM Thread Starter
cwill29
I'm not sure if this is the only way to get the factory shackles off but I used an air powered grinder. I just wanted anyone who is considering installing shackles to know that it is not as easy as people make it sound. The fronts were a piece of cake, the rears sucked! (it took about 1/2 hour to cut through each bolt)
The urethane bushings were a little too tight also. I guess I should have cut a little bit off them to make them fit but I didn't think of doing that until after I took them out and just used the original rubber ones in back. Total time was about 14 hours for one person.
I installed Currie boomerangs front and back. They're sweet looking plus give about 1/2" lift.
cwill29 is offline
post #2 of 4 Old 10-21-2002, 02:41 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Fallout and I did the shackles on defCon1's Jeep last weekend when we did the 4.5" RE ExtremeDuty lift .. with the two of us working on it, we had the rear shackles removed in under 1/2hr.
We didn't damage the bolts or anything .. came apart very nicely. Many thanks go out to Moabster for his writeup on removing the shackles .. we refered to them a couple of times to make our job easier
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 4 Old 10-21-2002, 04:42 PM Thread Starter
cwill29
YJ shackles
I have a '92 YJ Renegade so the rear shackles are probably harder to get to because of the body kit. The bolts are inside out so you can't just slide them out because they hit the gas tank. The Renegade is cool but the body work can be a pain to work around sometimes.
cwill29 is offline
post #4 of 4 Old 10-21-2002, 05:03 PM
NaeKid
NaeKid's Avatar
I just did a search for Moabster's original post from several moons ago (ok .. a month ago) and actually found it.
http://www.jeepforum.com/forum/showt...threadid=19350
His straightforward step-by-step was perfect for us ..
Silver
NaeKid is offline
M.O.R.E. Shackle install Jeepster197 YJ Wrangler Technical Forum 12 04-10-2013 09:21 AM
2" shackle install Q. BRAX YJ Wrangler Technical Forum 11 01-12-2008 07:33 PM
Shackle lift install HELP BuffaloYJ YJ Wrangler Technical Forum 21 09-28-2007 12:50 PM
possible shackle install problems iwishihad1 YJ Wrangler Technical Forum 15 11-02-2006 09:02 AM
Shackle Install Question Nine5YJ YJ Wrangler Technical Forum 3 03-04-2003 10:47 PM
