YJ SEAT SWAP(Need new risers) - JeepForum.com
post #1 of 21 Old 09-29-2013, 04:14 PM Thread Starter
brandon_gears
I bought some new seats but they sit too high, the brackets need to be lower. I need diimensions for lower seat brackets.
brandon_gears is offline
post #2 of 21 Old 09-30-2013, 01:22 AM
timatoe
timatoe's Avatar
Gonna be kinda hard for someone to give you good deminsions not knowing how tall your seats are etc. I fabbed up some quick ones for mine using a tape measure and a level. It was kind of a pain but it wasn't too bad. Don't have access to my pictures right now. I'll try to remember tomorrow before coming in to work and I'll post a couple of what I did.
timatoe is offline
post #3 of 21 Old 09-30-2013, 06:18 AM
ReDinTX
What height from floorboard are yalls stock seats? Or height from bottom of door opening?
PO out in bestop seats and i think they ride high since im almost looking out over the windshield an in only 5'9. I guestimate my seat to sit about 5-6" above bottom of door opening.
-ReD
Fire Lieutenant/Paramedic
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #4 of 21 Old 09-30-2013, 07:06 AM
Eron
And while you are at it, why not give us some actual information. You may as well have said " I need to replace that one part, you know? That one part ".
What year? Type of seats you are putting in? How much taller they are than stock? You may not realize this. But giving as much info as possible can be helpful at times. None the less good luck man! Ive been watching all the " Seat replacement " threads for some time. Getting ready to do some myself.
Eron is offline
post #5 of 21 Old 09-30-2013, 07:24 AM
HaskiE
HaskiE's Avatar
I did the same thing - but didn't want to loose the forward folding action of the riser, so I stabbed in a tilt-wheel setup. gave me the extra inch I needed for my lard.
my 2c
#theneverendingaxe
HaskiE is offline
post #6 of 21 Old 09-30-2013, 08:50 AM
bpounds
bpounds's Avatar
Yeah, more info sure would help.
If you bought brand new seats, my suggestion is that you sit on them for about a week before you make any decisions about changing the height. The foam will compress and conform to your butt pretty quickly.
A tilt column would be so nice. That's something I might do some day.
bpounds is offline
post #7 of 21 Old 09-30-2013, 09:15 AM
HaskiE
HaskiE's Avatar
really wasn't that hard, I got the column off a cherokee, and modified it a bit
#theneverendingaxe
HaskiE is offline
post #8 of 21 Old 10-01-2013, 06:58 PM Thread Starter
brandon_gears
95 yj, xrs seats, they sit about 4 in higher, i'm 6'3
post #9 of 21 Old 10-10-2013, 06:14 PM Thread Starter
brandon_gears
can you post them??
post #10 of 21 Old 12-20-2013, 09:36 AM
heffay
heffay is offline
post #11 of 21 Old 12-20-2013, 12:57 PM
timatoe
timatoe's Avatar
can you post them??
Totally forgot about this thread. Now it's two months old.
Dang, that looks like a lot of work for some seat risers. If it works for you that's all that matters.
BTW, anyone else reading this in the future, here's the basic angle and 1" tubing set up I did.
I don't have any real detailed pics or diagrams etc. just some shots to get the idea....
Hope that's helpful to someone.
timatoe is offline
post #12 of 21 Old 12-20-2013, 02:14 PM
heffay
Hmmm. Not exactly sure how to take that last comment.
Why would sectioning existing risers be any more complicated than building from scratch? I had to measure 1.5" four times and the rest falls into place. Maybe it looks complicated because I actually went to the effort to document it properly.
I also didn't have to add any steel to this project. If it ain't broke, don't replace it, just mod it.
heffay is offline
post #13 of 21 Old 12-20-2013, 05:50 PM
timatoe
timatoe's Avatar
It just meant it looked like a lot of work. I suppose it looked that way because I didn't realize you were just chopping an existing riser, that's not a stock riser btw.
timatoe is offline
post #14 of 21 Old 12-20-2013, 06:52 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
I didnt know yj's didnt have tilt. mine does. wish i had the fold up seat on driver side though
-April '14- YJoTM- June '15
The_Goob is online now
post #15 of 21 Old 12-20-2013, 07:25 PM
YJ4LIFE
my next project is lowering my seats with the stock tilt mechanism. I started it but got sidetracked with the EFI swap. its doable. grinding off those swagged pins in a pain. I tried drilling one out but it didn't work so well.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
brackets , riser , seat , swap , YJ
