YJ runs hot/fuel gauge no workie - Page 3 - JeepForum.com
post #31 of 34 Old 04-06-2010, 09:55 PM
AZoriginal
1) Sounds like your radiator isn't getting enough air flow. You may try to take an air compressor and blow through from behind it, in the engine compartment.
2) It's a common problem, seems like every YJ has it. My old one stopped at 1/4 tank. I've heard that people have been able to fix it by cleaning the terminals on the tank, and also cleaning the terminals on the back of the gauge.
3) Sounds normal to me. In fact, that's pretty good. When the engine heats up, the oil loses viscosity (becomes less "thick") and it moves much easier, leading to lower engine oil pressure. My old YJ used to maintain about 25 PSI at idle when it was fully warmed up!
I replaced the radiator today with a new aluminum. Apparently the old one was not getting enough flow to cool the engine at sustained high speeds. Now the engine stays at a consistent 210 degree (half way on the guage) under all driving conditions. One problem solved.
I ran out of gas today (on purpose) to see if the fuel guage would ever move south of half, it didn't. So, I guess the next step is to start tearing apart the guage cluster and drop the tank. Any other suggestions are welcome.
AZoriginal is offline
post #32 of 34 Old 03-10-2013, 09:29 PM
SSG1975
How many of you who have hot engines still have egr? Just wondering for my own knowlage.
SSG1975 is offline
post #33 of 34 Old 03-10-2013, 09:34 PM
jokerchief462
The EGR valve operates on deceleration. My 2.5L is stock and passes smog. Runs great but the engine temps never get much above 210.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #34 of 34 Old 03-10-2013, 09:35 PM
SSG1975
Oh wow!! this thread is 3 years old
SSG1975 is offline
Fuel Sending unit or fuel gauge? NHfireLJ YJ Wrangler Technical Forum 17 01-22-2010 06:41 PM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
98 Sahara no start no fuel gauge no volt gauge.Cps already changed... CrazyRobCustoms TJ Wrangler Technical Forum 5 03-25-2009 11:52 AM
Fuel gauge reading fuel all the time Sandbagger66 YJ Wrangler Technical Forum 6 04-30-2006 08:07 PM
Oil Pressure Gauge and Fuel Gauge problems phattdraggon YJ Wrangler Technical Forum 5 05-11-2004 03:12 PM
