YJ Rough Idle ater build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ Rough Idle ater build
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !
Unread 07-24-2012, 06:59 PM   #1
damian21783
I put together a 4.0 a while back and just had to throw it in the jeep a month ago always had a rough idle so i wanted to reset the distributor. I set it at 0 TDC put the distributor in number one is almost at 5 oclock position did everything in the book as said now its real rough almost like its missing Fireing order is correct I checked it a Few time. Any suggestion it says theres no timing computer does it all but thats what its almost like a timing issue?
damian21783 is offline   Reply With Quote
Unread 07-24-2012, 07:40 PM   #2
superj
1987 YJ Wrangler
you cannot adjust the distributor, can you? maybe your timing chain is a tooth off one way or the other
A lot of teenagers are people who express a burning desire to be different be dressing exactly alike.
Panties aren't my favorite, but they're right next to it...
No one is normal, there are just a lot of weird people with things in common.
superj is offline   Reply With Quote
Unread 07-24-2012, 08:13 PM   #3
rambo3489
Check for an intake manifold leak? Hows it run when you get the RPM's up a little. It its OK then I vote for intake manifold leak. If it still runs like crap then its something else.
89 YJ.. My first jeep and will be around for years to come. ▀||||▀
Current project: Ford 9" spooled 35 spline, HPD44, Along with all the good stuff: Suspension, SYE, drive shafts, tummy tuck, armor.
Build Thread: http://www.jeepforum.com/forum/f22/my-yj-build-adventures-thread-1356941/
rambo3489 is offline   Reply With Quote
Unread 07-25-2012, 06:38 AM   #4
Que89YJ
You put it together. The question is mechanically are you sure you are 100%. Do a compression test. First place to start. Also check for fault codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline   Reply With Quote
