YJ right side turn signal wiring - Page 2 - JeepForum.com
post #16 of 22 Old 07-20-2013, 03:21 PM Thread Starter
MNmilitaryGUY
So I removed the clips which was weird the weren't even doing their job of joinin two wires they were just there. I plan to go ahead and cut away the area that the clips cut the wires and add new wire. When I l followed back to the other side I found this
MNmilitaryGUY is offline
post #17 of 22 Old 07-20-2013, 03:38 PM Thread Starter
MNmilitaryGUY
That's where the Scott clips were doing nothin
post #18 of 22 Old 07-20-2013, 04:48 PM Thread Starter
MNmilitaryGUY
Here is where the rear wiring meets the main wiring harness
post #19 of 22 Old 07-24-2013, 07:06 AM
Myjeep1986
turn signal
check out just jeeps.com, service manual section pages 108 and 109 under wiring diagrams; shows the plugs and wiring for both sides;
the harness drops down from interior over left wheel well at roll bar flange, this plugs into the left pigtail of the light behind the left corner above the gas tank and then the other plug runs acroos the tank to right corner and connects to the right plug pigtail; Looks like PO spliced in a trailer hitch plug and connections are broken /corroded;
Myjeep1986 is offline
post #20 of 22 Old 07-24-2013, 08:22 AM Thread Starter
MNmilitaryGUY
I can see where your comin from with the trailer hitch guy had two balls welded on some make shift pumper BS yeah I think I'm gonna try and find the whole rear wiring hose and just plug and play
post #21 of 22 Old 07-24-2013, 09:24 AM
Siva283
Once you get this straight for future reference if you need trailer wiring get a TJ trailer harness from u-haul (23.99). There is no splicing they are plug and play. It plugs into the lighting pigtail. Its literally a ten minute install. I know this works for 95's and 94's but I am pretty sure its good for 91 and up.
Ask me how I know...
Siva283 is offline
post #22 of 22 Old 07-24-2013, 10:08 AM Thread Starter
MNmilitaryGUY
Appreciate it.
