yj rides insanely rough, please help - Page 2 - JeepForum.com
post #16 of 24 Old 06-25-2013, 01:52 PM
TSEJEEPERS
Originally Posted by jsipe007 View Post
As others have stated, one thing to try is loosening the shackle bolts to the frame and spring and re-torquing. I went and got new hardware, lubed my bushings and teflon pads. I got locking nuts for the shackle bolts so I could tighten them to 35-40 pounds instead of the factory 80-90. Before doing this though, you can try flexing your rig, if the shackles dont move like they are supposed to, theyre probably overly tightened.
For clarification, did you ditch the trac bar in front or just the sway bars? The first thing I did was toss the front and rear trac bars into the scrap pile.
finally, as others have stated, the spring brand makes a huge difference. Procomp and Rough Country are two companies known for really stiff YJ springs. I know cuz I have 2.5inch procomps. I finally got her to flex good, but the ride is not nearly as sweet as a set of OME springs. Your profile as others stated says youve got BDS springs. Are you sure theyre BDS?
I hate to disagree with you but by torquing your shackle bolts to 35-40 pounds what you have done is let the shackles move on the bolt.
What this will do is either wear the bolt out or oblong the holes in the shackle.
As Anti picture shows the sleave in the bushing is the thing that should move.
That is why there are greasable shackles.
Pull the sleaves out and grease those, then torque to factory spec.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #17 of 24 Old 06-25-2013, 02:00 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Never had any signs of wear on my bolts or shackles being torqued to 40ftlbs for 8 years. On my 95
Sent from AutoGuide.com App
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #18 of 24 Old 06-26-2013, 09:50 PM Thread Starter
Damon1995
my information on the left is incorrect.
this is updated and correct.
1994 yj
4.0
tf999
np231
d30 & d35(for now)
4.11's
BLACK DIAMOND SUPENSION 3.5" leafs. im an idiot i thot i had bds
1.5" lift shackles
15x10's 3.75" backspacing
35x12.50x15 bfg a/t
i think i ride so rough because on the black diamond springs. i have read they are junk. do you guys think this is why my ride is insanley rough? im trying to upload pics but it keeps saying upload failed. thanks for your input guys, much apreciated
Damon1995 is offline
post #19 of 24 Old 06-27-2013, 05:36 AM
rykerjenbob
I have the black diamond lift on my 95 and yes it rides rough, especially with the shocks it came with. Hopefully going to bilsteins in the future would help.
rykerjenbob is offline
post #20 of 24 Old 06-27-2013, 08:01 AM
StanF
What tire pressure are you running?
That makes a huge difference in my Jeep. I run 28psi in my 32s.
StanF is offline
post #21 of 24 Old 06-30-2013, 09:59 PM Thread Starter
Damon1995
i run about 20 psi to help with the insanely rough ride
post #22 of 24 Old 06-30-2013, 10:07 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Based upon what I've read, I'd make sure your shocks are not maxed out and acting as the stops for the suspension travel. I just found that issue on my co-worker's Cherokee after he did a lift. the rears had no downward travel due to improper shock length and made his veh ride horribly over even the smallest bump.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #23 of 24 Old 06-30-2013, 10:10 PM
Luuca
Luuca's Avatar
Originally Posted by Damon1995 View Post
? im trying to upload pics but it keeps saying upload failed. thanks for your input guys, much appreciated
How to Post Images, Step By Step
YJOTM never
Luuca is offline
post #24 of 24 Old 07-01-2013, 11:15 AM
Scorch1969
i have 4" lift rough country springs and stiff is right, next set will not be rough country
Scorch1969 is offline
