YJ repairs - JeepForum.com
post #1 of 9 Old 02-20-2003, 12:43 PM Thread Starter
shookwell
shookwell's Avatar
YJ repairs
i took the YJ im looking to buy to the mechanic today. he said it needs a new muffler, oil pan, and front brakes + rotors. how much will these run me? also, is it worth going for OEM parts, are they any better?
thx
shookwell is offline
post #2 of 9 Old 02-20-2003, 03:01 PM
PoorFool
OEM
I certainly don't think there should be a significant difference in quality between OEM and aftermarket on those items. In fact, you can probably spend the same money on aftermarket and get upgraded components. The oil pan is straight forward. But a set of high quality brake pads is probably still cheaper than the dealer can offer.
If it were me I'd go cheap (within reason) on brakes and oil pan, then get a good hi-flow muffler and after-cat system to boost power.
Is the oil pan bent? I have a 2.5L and bent mine over a year ago. Still runs fine and doesn't leak.
Tommy
Turbocharged 4.0, 35" Kevlars, 33 spline Detroit D44, 4.88s, heavy foot.
PoorFool is offline
post #3 of 9 Old 02-20-2003, 03:25 PM Thread Starter
shookwell
shookwell's Avatar
no it just has a lot of rust. it and the muffler are the only parts with rust though, dunno why?
post #4 of 9 Old 02-20-2003, 04:00 PM
PoorFool
Rust?
I've never seen one get rusty. I thought they were made with galvanized metal so they don't rust. Who knows?
Anyway, I wouldn't replace it unless there is some specific problem with it. As long as it holds oil and isn't leaking horribly, I wouldn't jack with it. It can be a bit of a pain and somewhat costly.
What year is it and how many miles does it have? If it has less than 100k you can probably just have the rotors turned for $20 each and get some new pads. If you can do it yourself, it would probably be less than $100 total for the brakes. My 94 has about 68k on the stock rotors and pads, although they're about due for some work.
I don't know if you have a Midas around, but they offer (or used to) a lifetime warranty on their mufflers. A friend of mine has had his replaced 5 times due to rocks tearing holes in them, all free of charge.
Good luck with your purchase!
Tommy
PoorFool is offline
post #5 of 9 Old 02-20-2003, 04:01 PM
yjynot
muffler = !9.99 cheapo
each rotor and brake pads..=$25.00 per side
oil pan,,,sounds like he wants ya to bend over... scuff yours up and put some paint on it
yjynot is offline
post #6 of 9 Old 02-20-2003, 04:32 PM
Snowbird
Agree with everything yjynot said with one caveat: if the pan is leaking oil through it, you need to replace it. Both oil pans and rear end covers can corrode through from a combo of oil and water = acid formation.
Your oil pan might be leaking through, but it might just be from another source.
In any case, only the brakes and muffler need fixed asap.
The rotors can be turned if they are not beyond specs.
Any chance you can do the work yourself?
Snowbird is offline
post #7 of 9 Old 02-20-2003, 05:44 PM
Bob K
Bob K's Avatar
My oil pan rusted out. My mechanic, who is very honest, said not to worry about it. The leak will gradually get worse, but it won't just drop out on ya without warning. I eventually did replace it. My original oil pan had a skid plate. I didn't want to compromise that so I searched far and wide. I couldn't find a new one. So I eventually bought a used one in excellent condition for fifty bucks on EBay. Good luck.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #8 of 9 Old 02-21-2003, 03:10 PM Thread Starter
shookwell
shookwell's Avatar
thx for the input
the muffler definately needs replacing, besides being rusty, the clamp broke off and its bent.
the oil pan isnt rusted through, its not losing any oil, he said it will have to be replaced within 6 months to a year. the brakes probably need new rotors, the jeep is just past 99k
post #9 of 9 Old 02-21-2003, 04:17 PM
93yj35
i believe that skyjacker makes a high clearance oil pan that holds another 2 quarts of oil and is made of solid steel.
98 Tj stock 2.5l
93yj35 is offline
How much for repairs Bionix YJ Wrangler Technical Forum 27 07-29-2011 07:50 PM
Frame repairs sjwrangler YJ Wrangler Technical Forum 1 01-21-2009 02:53 PM
97 Wrangler Repairs twarden TJ Wrangler Technical Forum 16 03-26-2008 03:12 PM
Tranny Help - Need Repairs Bethlehem TJ Wrangler Technical Forum 4 02-13-2006 07:32 PM
a few repairs nblax TJ Wrangler Technical Forum 0 07-07-2004 08:10 PM
