YJ Rear Round Tail Lights? - Page 2 - JeepForum.com
post #16 of 33 Old 05-08-2007, 06:38 PM
timatoe
timatoe's Avatar
Originally Posted by denwagh
Walmart has something incandescent that has the grommits and will flush mount? I was actually not wanting the LED's for a more classic look.
Yep, in the local one here (well about 40 miles away) they're right below the trailer wiring crap.
timatoe is offline
post #17 of 33 Old 05-08-2007, 06:43 PM Thread Starter
denwagh
Neat.. Thanks!
denwagh is offline
post #18 of 33 Old 05-08-2007, 06:46 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
use a hole saw on a drill.
i haven't done 4" round tails but if the lights are 4" then you'll need a 4 1/2" hole i would think.... figure that out before you drop the money on a hole saw that's too small.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #19 of 33 Old 05-08-2007, 06:49 PM Thread Starter
denwagh
4' seems a little small to me, I figured 6 or 8... I've got a nice set of hole saws so we shall see.
denwagh is offline
post #20 of 33 Old 05-08-2007, 07:11 PM
NewdRiver_
Hey Big-n-Broke....are you missing the rear body mounts in the picture you posted?
NewdRiver_ is offline
post #21 of 33 Old 05-08-2007, 07:29 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
yea i didn't like how they looked with the 2" body lift so i cut them off
actually.... when doing the comp cut they had to go. when i build my new cage i'll work body mounts into my design. in the meantime it'll have to sit on the other 9 body mounts so far no problems missing those two. there is another about 6" from the rear in the middle...
-Erik
post #22 of 33 Old 02-25-2013, 08:07 PM
theh86
so do they also act as blinkers as well? or would i need to to a 2" amber and 2" clear for that? i was looking to do this as well but was not sure if they would work new to all this still
theh86 is offline
post #23 of 33 Old 02-25-2013, 08:26 PM
rambo3489
Don't do a kit. Unless you want to pay a chit load for it. Check out raneys truck. They have a good selection of quality lights. All you need is the light a pigtail bitt connectors and a way to make a hole.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #24 of 33 Old 02-25-2013, 08:29 PM
rambo3489
Depends on your states law for the amber blinker. You can get the LED tail light with integrated backup lights. Pretty simple and straight forward to wire up properly.
Your going to need an EL-12(I think that's right) electronic flasher for them to work. You can get it at auto zone.
<a href="
THE YJ MY WAY</a>
post #25 of 33 Old 02-26-2013, 12:11 AM
imstillatwork
2007....2007...2007....BAM! Twenty Thirteen!
imstillatwork is offline
post #26 of 33 Old 02-26-2013, 12:17 AM
Carlos14
We're shoveling them up today!
Luck Favours The Prepared
Carlos14 is offline
post #27 of 33 Old 02-26-2013, 05:57 AM
bogleparsons
I didn't need the relay, weird some people do, some dont.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #28 of 33 Old 02-26-2013, 06:30 AM
gunshw301
Hey at least the search is getting a workout.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #29 of 33 Old 02-26-2013, 07:54 AM
bogleparsons
Damn didn't notice the Necro DOH!
post #30 of 33 Old 02-26-2013, 11:50 AM
imstillatwork
I always joke about the necros, but that's totally true. SOMEONE ACTUALLY SEARCHED!!!
flush mount led round tail lights? 02OlllllllOTJ TJ Wrangler Technical Forum 5 01-02-2010 09:51 AM
looking for a good set of round tail lights and some tips pigpen8304 TJ Wrangler Technical Forum 15 01-04-2008 10:13 AM
round/flat tail lights bughunter YJ Wrangler Technical Forum 37 10-13-2006 08:30 AM
Round tail lights? TheBoogieman TJ Wrangler Technical Forum 10 09-22-2006 06:29 PM
My new round tail lights H8PVMT TJ Wrangler Technical Forum 32 07-19-2004 07:02 PM
