yj questions help please - JeepForum.com
post #1 of 16 Old 02-08-2013, 11:50 PM Thread Starter
metalmulisha
i am looking at 3 different yj one is a 93 with a 4.0 conversion with a aw4 auto tranny soft top half doors, one is a 95 with a 4 cyl. hard top hard doors with a 5 speed, and then a 91 4.2 5 speed with soft top and half doors my question is should i even consider the auto and does the hard top and hard doors out weight the 4 cyl vs the soft top with the 4.2l 5 speed if any one has some insite on the this please chime in thanks
metalmulisha is offline
post #2 of 16 Old 02-09-2013, 02:27 AM
mdemieville
The 91 is supposed to have a 4.0 in it as well. Personally I like hard tops better due to noise, and those darn zippers that always come off track. I also find the hard top holds in the heat a little better. Then there is always the issue of ripping your soft top. I also prefer the 6cyl over the 4 banger. Just my 2 cents
1989 YJ 4.2L 5 Speed
1993 ZJ 4.0L Auto
mdemieville is offline
post #3 of 16 Old 02-09-2013, 04:49 AM
Jeepsr4me
If the 91 has the 4.2 in it, run away from it. You can always buy a different top. But it takes some work to get a aw4 under a jeep the right way.
So of the ones you posted I would go for the 93 cause if done right, that combo of engine and trans is a good one.
Jeepsr4me is offline
post #4 of 16 Old 02-09-2013, 06:54 AM
CBinDC
Why run away from it? I have a 4.2 and it runs great! Albeit, mine is carbed but I love it. The 91 has multi port fuel injection. The 4.0L's came fuel injected starting in 91.
Between the '91 and '95, it would come down to mileage for me. What is the mileage on these vehicles?
CBinDC is offline
post #5 of 16 Old 02-09-2013, 08:18 AM
Jeepsr4me
Because if someone went to the trouble to take out the fuel injected engine and put in the carbed 4.2.
I hate that carbed crap. off angles offroad and the engine dies. Hit a bump too hard, engine dies, And unless they changed to a better carb, the stock one is worthless. I hate carbs
post #6 of 16 Old 02-09-2013, 10:26 AM Thread Starter
metalmulisha
not sure about the miles on the 93 or 91 but the 95 4cyl has 145,000 the 91 and 95 look to be in better shape four around the same price 4,000 but iam going to do my best hammering the prices down another question is that they all have 33 on them and the 95 and 93 have 4.10 and the 91 should have 3.07 3.54 or 3.73 i would like to run at least 33 but would like 35 should i worry about the 91 gearing with the straight 6 or will it be ok i have a buddy that has a 01 tj with 35 4.10 and 4cyl and seems to do fine but its no speed demon im not worried about the speed just and daily driver weekend worrier for now the 95 is a rio grande and 91 is a sahara i believe thank for the input
post #7 of 16 Old 02-09-2013, 10:31 AM
jhartley
My 91 was a 4cylinder and was swapped to a 4.2 carbed engine it was a wiring nightmaire I ended up buying harnesses off eBay when I did my 4.0 swap
jhartley is offline
post #8 of 16 Old 02-09-2013, 12:50 PM
CBinDC
Here's a gear chart to check out: http://www.quadratec.com/jeep_knowle...article-26.htm
As you can see, it kinda does matter what gears you have. If the 91 has 3.07 or 3.54 gears, fifth gear will be useless with 33s and 35 will be a nightmare. For me, that knocks the '91 right off the table, unless you don't mind swapping the front and rear axles for ones with 4.10 gears.
On this note, I would scrap the 4 banger, as well. That leaves the 4.0 with auto trans. Personally, I don't get the point of a Wrangler with Auto trans. Although it can come in real handy if its a DD, you live in the city, and you are always dealing with rush hour traffic. Double check the mileage on that transmission. Anyways, that's my 2c.
CBinDC is offline
post #9 of 16 Old 02-09-2013, 12:56 PM
CBinDC
Is that what happened? Someone went through the trouble to remove the fuel injection? I don't get it. The original Carter carb is not very good. That's why I swapped mine out with a MC 2150, did the nutter, and upgraded the ignition. It runs much, much better now. I've had no problems with it. Not to mention, it is way easier to tune a carb than FI.
CBinDC is offline
post #10 of 16 Old 02-09-2013, 01:38 PM
Sparrows
My YJ has the AW4 swapped in and I love it. Drove a manual for about 10 years and now I don't think I would ever go back from the auto (unless it was a sports car or something similar.) In fact yesterday I went out wheeling on a narrow, rutty, mountain trail that was completely iced up under the snow. We made it about half way though the trail when we hit a hill that was so icy neither of us could make it over. We ended up having to back down the trail for about 30 mins to get to a spot where we could turn around.
Because of the ice and snow I had to pump the breaks the entire ride down to prevent the tires from locking up and going into an uncontrolled, backwards slide. When we finally got turned around all I could think of was "god with a 5 or 6 speed I don't think I could have done that! I would have stalled it over and over trying to frantically work the brakes, clutch, and gas while trying to keep from sliding off the side of the mountain. No thanks!"
As far as full doors, half doors, hard tops, and soft tops are concerned, that just comes down to personal preference. My TJ had both a hard top and a soft top when I bought it. Maybe a week after I got it home, I took the hard top off for the summer. Fall came and I put the soft top up. The hard top sat exactly where I left it for nearly 8 years...I never had a problem with the rag top and the hard top is just a PITA to take on and off (especially without help!) and awkward to store when its off. I had full doors on my TJ but always wished I had half doors. Now my YJ has half doors and I love them. They are just more "Jeep" to me. No other vehicle has half doors!
There's my .02
Cheers
June '13 YJOTM
Sparrows is offline
post #11 of 16 Old 02-09-2013, 03:41 PM
CBinDC
Sparrow, you make some very valid points, especially about the hard top.
CBinDC is offline
post #12 of 16 Old 02-09-2013, 03:57 PM
maxthegi
I run a soft top with half doors. I know people say that hard tops hold in heat better but here in the winter it gets down to about 20 and it snows. I never have a problem staying warm in my jeep. I'm often turning the heater down because its too hot. Good luck.
maxthegi is offline
post #13 of 16 Old 02-09-2013, 04:22 PM
Que89YJ
The 95 has other a less obvious advantage. The 95 has gavantized body and frame. The other consideration is where you live. Trying to climb any grades with the 2.5L will drive you nuts with the 2.5L. The 4.0L or 4.2L would be better suited for Oregon driving. You are dealing with PO mods on the 1 and 3. If you think you can deal with the slow crawl of the 2.5L then the 95. If not then the 93.
Que89YJ is offline
post #14 of 16 Old 02-09-2013, 06:39 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
I have a 4.0 automatic. Love it and would not trade for manual. I did Black Bear Pass and Redcone (Before it was repaired) in Colorado. Also use my Jeep on some huge dunes. No manual for me.
"Under certain circumstances, profanity provides a relief denied even to prayer." - Mark Twain
Chrisnvegas is online now
post #15 of 16 Old 02-09-2013, 08:07 PM
CBinDC
I can respect that. I really didnt mean to come off as ignorant when I said I can't imagine an auto Wrangler. I'm not being apologetic, just explaining myself. I really have no reference because my YJ is the only Wrangler I've owned, since I bought it new in '89. That's all. Actually, the idea of not having to shift is nice. My z71 is auto and I love it.
CBinDC is offline
