YJ questions - JeepForum.com
post #1 of 19 Old 10-05-2013, 05:44 PM Thread Starter
jared-f
YJ questions
Just got a 1989 yj lifted on 35's, love it so far just having a few problems to sort out..
ok so when im running:
sometimes stalls in reverse if you're not on the gas
hard start when the motor is hot, have to hold the gas all the way down for it to start
stalled at idle with the a/c on
seems to have a little bit of a rough idle, maybe idling too low?
that being said, I know alot of people aren't fans of the stock carbs on these. So does this sound like a carb/tuning problem that can be fixed easily?
also what carbs do yall recommend for an 89?
Another thing is my right window regulator is broken and the cheapest i've seen is like $80, anyone have a tip on a cheaper route?
Thanks for all the help and awesome info on the forum,
Jared
jared-f is offline
post #2 of 19 Old 10-05-2013, 07:09 PM
jred
What RPM is it idling at? Did it sit up for a while before you got it? Does it have fresh gas?
Without knowing your specific vehicle, I'd check:
Fresh gas
Air filter
Spark plugs
Plug wires
Rotor button thingy
Distributor cap
Basically a tune up.
Check the condition of any vacuum lines, a bunch of my rubber elbows were dry rotted.
Fuel pump/pressure both cold and hot.
If all that checks out, I'd start thinking about a good clean/rebuild of the carb. Depending on your ability & costs for a shop to rebuild, you might come out better to replace it. I'd do the other stuff first, though. Typically I'll start with the cheapest possible fix & move up to the most expensive.
jred is offline
post #3 of 19 Old 10-05-2013, 08:00 PM
YJ4LIFE
4.2L or 2.5L?
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #4 of 19 Old 10-05-2013, 08:43 PM Thread Starter
jared-f
Sorry completely forgot to mention, 4.2L
jared-f is offline
post #5 of 19 Old 10-05-2013, 08:59 PM
dancytron
To really help, we need to know what's been modified on it already.
Stock, it has a pretty complicated computer controlled emissions setup that can cause lots of problems if it isn't all working correctly. See this for how it works stock. http://home.sprynet.com/~dale02/list.htm The factory service manual will tell you how to troubleshoot it.
Lots of people bypass the computer and set it up like a pre-emissions (1979 or so) jeep. See http://www.jeepforum.com/forum/f8/ho...bypass-522262/
dancytron is online now
post #6 of 19 Old 10-05-2013, 09:09 PM Thread Starter
jared-f
Thanks you for those links, I'll check it out tomorrow and read into it. But as far as modifications, it's pretty simple just lifted and bigger tires
jared-f is offline
post #7 of 19 Old 10-06-2013, 01:38 PM Thread Starter
jared-f
When the motor is warm, the idle when in park is around 1250 and when in drive and on the brake it's 750/800
jared-f is offline
post #8 of 19 Old 10-06-2013, 04:37 PM
jasonjones21
Originally Posted by YJ4LIFE
4.2L or 2.5L?
2.5 fuel injected you know nothing
jasonjones21 is offline
post #9 of 19 Old 10-06-2013, 08:32 PM
superj
Something is not set right in the carb setting or timing if it idles at 1250 in neutral but at 750 in gear. Look for a vacuum leak before anything else
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #10 of 19 Old 10-06-2013, 08:34 PM
timatoe
timatoe's Avatar
Also Google "Carter BBD Venturi Tube"......
timatoe is offline
post #11 of 19 Old 10-07-2013, 12:09 AM
gtg413i
2003 WJ
Did some of these yjs come with power windows?
Brian's Black Betty Build:
gtg413i is offline
post #12 of 19 Old 10-07-2013, 12:48 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
No.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #13 of 19 Old 10-07-2013, 12:56 PM
jasonjones21
Is there any aftermarket?
post #14 of 19 Old 10-07-2013, 01:09 PM
Sparrows
Lol.
My drivers side soft zipper is busted. I cut some slots and rand some velcro through them until I have the zipper replaced. The things you learn to live with when you're in love with your Jeep!
If not having power windows is bothering you, you are in a world of hurt!
Cheers
June '13 YJOTM
Sparrows is offline
post #15 of 19 Old 10-07-2013, 01:21 PM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Is this a stick or auto ?
Assuming your not suffering from a vacuum leak caused by the carb base or other major components, the idle and stall issue is not really that hard to track down "if" you have all the stock sensors and emission components still installed. All you need is a DMM and Vacuum gauge, and the pin outs to the diagnostic ports from the link provided previously.
There are some 'step by step' tasks to do that are in the FSM but they can be easily paraphrased if you don't have access to that.
A 4.2L auto w/ ac are different for it then a manual tranny would be, and the fast, hold and a/c on idle settings need to be set and have a multiple phase setting sequence that should be detailed on the sticker on your hood.
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
