YJ Proportioning Valve - JeepForum.com
post #1 of 2 Old 09-09-2005, 09:42 AM Thread Starter
martyb
I've got a leaky proportiong valve in my CJ and the cheapest solution was the junk yard. Ive got two YJ p-valves, but the holes aren't the same location. Can anyone tell me, off the top of their head, if the is the correct I/O of the thing? thanks
edit: apparently i was wrong. found this on the autozone web site
martyb is offline
post #2 of 2 Old 09-09-2005, 08:18 PM
Cobra Jeep
You have it backwards. On the pic your drew the ports on the left are for the rear. The ports on the right are for the front, top one is input, and the two lower ones are for the two front wheels. Shouldnt matter witch one goes to witch wheel.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
8.8 and proportioning valve tcox TJ Wrangler Technical Forum 4 06-18-2007 11:02 AM
proportioning valve help tn_yj YJ Wrangler Technical Forum 7 05-27-2006 03:33 PM
Which Proportioning valve do I have? jeffjeep1 TJ Wrangler Technical Forum 4 11-11-2005 10:10 PM
Proportioning valve? Glass TJ Wrangler Technical Forum 12 09-20-2005 09:48 PM
YJ Proportioning valve wild_weazel YJ Wrangler Technical Forum 1 05-17-2003 10:59 PM
