YJ Project.....Kind Of. - JeepForum.com
post #1 of 12 Old 04-22-2010, 09:41 AM Thread Starter
GumboroJeep10
Hi All,
My name is Josh, and I'm new to the forums here. I just bought a YJ from my brother for $1000, what a deal! But, it does need some minor work. Firstly, Where is the best place to buy replacement parts? Secondly, I am having a problem with the engine. The jeep runs pretty great for the most part, I can run it as much as I want and it will get me to where I need to go. The problem is that it intermittently stutters, almost like your loosing gas. It does that for about 30sec-1min then it stops and runs fine, until it happens again. I have tried fuel injection cleaner, changed the oxygen sensor, and the IAC Motor. The injectors have also been changed. I have taken it to a Chrysler dealer and they couldn't find any problems. Any help here guys?
Thanks!
GumboroJeep10 is offline
post #2 of 12 Old 04-22-2010, 10:04 AM
FOURWALLYS
Originally Posted by GumboroJeep10 View Post
Hi All,
Thanks!
Honestly, just start using the search feature on JF. You can practically type in anything on here, and you will find similar problems, with tons of advice on diagnosis. Have you tuned it up to start with, plugs/wires/distributer, new air filter, pcv. Search "Nutter Bypass", I haven't done mine yet (probably next week) but it pretty much is the cheepest mod that gets the most bang for the buck.
I have a love/hate relationship with my jeep. I love it, it hates me..........
FOURWALLYS is offline
post #3 of 12 Old 04-22-2010, 10:06 AM
Toms87
1987 YJ Wrangler
Nutter bypass is only good for the carburetor engines. OP, your best bet is to yank out your 2.5 and put in a V8
Toms87 is offline
post #4 of 12 Old 04-22-2010, 10:08 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Check the fuel filter too. It's mounted along the inner framerail by the driver side rear tire.
Joe Dillard is offline
post #5 of 12 Old 04-22-2010, 10:11 AM
FOURWALLYS
Absolutely right, sorry, I didn't look at his year......
post #6 of 12 Old 04-22-2010, 10:29 AM Thread Starter
GumboroJeep10
I would love to put a V8 in it if I had the money for that right now lol! I had the fuel filter changed already, and it was very dirty. But, changing it didn't make a big difference in performance . Could it possibly be a computer problem?
post #7 of 12 Old 04-22-2010, 10:43 AM
Que89YJ
Check your fault codes first. The method is listed under the FAQ. You need to figure out if it is fuel, air, or timing. strart with checking the faults the go out to the local auto parts store and rent a pressure guage. There is a nipple on the fuel rail to measure the fuel pressure. Hook it up and watch the fuel pressure when its happening to see if it changes. Fuel pressure should be 31-40psi. BTW you get your money back when you return the tool.
Que89YJ is offline
post #8 of 12 Old 04-22-2010, 10:46 AM
youngYJ95
Check out the TPS it might just need to be cleaned, the CPS could probably use a good cleaning as well seeing as how it is 15 years old. Mine runs great now with a new TPS and clean CPS. Good luck!
[Originally posted by rulppa: But no, there is no change is power.. and my arse-dyno is pretty accurate]
youngYJ95 is offline
post #9 of 12 Old 04-22-2010, 10:51 AM
maricopanate
i actually had the same syptoms when i joined this site a couple years ago(just had to get new user/pass because i hadn't been on so long i couldn't log in-different email i guess) if you search it, i think it feb or march of 2008 on this forum. the guys here had lots of helpful suggestions. on mine i tried the easy stuff first-fuel filter, O2 sensor, but i ended up pulling the gas tank and found out that the sh@#%y stock rubber gasket for the the fuel pump was bad. it's been running great ever since.
maricopanate is offline
post #10 of 12 Old 04-27-2010, 04:06 PM
Toms87
1987 YJ Wrangler
I'm almost done my swap and almost out of money...
Did you ever fix the problem?
Toms87 is offline
post #11 of 12 Old 04-27-2010, 04:23 PM
firefighter315
Welcome to JF Josh! You'll find tons of useful info here.
I'd suggest ruling out individual components one by one. You've almost completed the fuel delivery system, just go ahead and work your way back to the source. New injectors should be fine (unless the problem didn't appear until after you put them in) and you've changed the filter. Check your fuel pressure at the rail and make sure your pump is getting the all the fuel where it needs to be. If not, drop the tank and swap out the pump. It'll probably need it sooner than later anyway if it is still the original. If there is a ton of gunk on the filter sock on the pump, have your tank cleaned before reinstalling. If you do end up dropping the tank, do the 15 to 20 gal. conversion while it is down. You can find the instructions all over this forum with a simple search. It'll take you and extra 5 minutes with the tank on the ground anyway. If you have the appropriate pressure at the fuel rail, start looking at the various sensors mentioned above.
Welcome to the Jeep world! It's all about trial and error and running down the list ruling out each suspect as you go. Be sure to find some time to wheel it too!
My YJ Build Thread
firefighter315 is offline
post #12 of 12 Old 04-27-2010, 09:45 PM
meangreeny
sure sounds to me like your tps is faulty.
meangreeny is offline
Project Green Monkey...a.k.a. Project Empty Pockets - '97 TJ Sport build thread Poobah TJ Wrangler Technical Forum 20 12-14-2008 09:30 PM
What kind of lift is this, what kind of shackles, PICS badassjeep04 YJ Wrangler Technical Forum 11 07-10-2008 03:54 PM
what kind of oil? jeeprocker TJ Wrangler Technical Forum 15 04-24-2007 02:52 PM
some kind of project H2_RECOVERY YJ Wrangler Technical Forum 5 11-05-2004 11:10 PM
What kind of YJ? Willie YJ Wrangler Technical Forum 5 09-09-2002 12:40 PM
