YJ Power Steering Return Line End Fitting FYI - JeepForum.com
post #1 of 8 Old 08-12-2011, 12:24 PM Thread Starter
Jax89Jeeper
Just wanted to add some info on the forums. If you have cracked the fitting that screws into the steeing box on the return side, it is next to impossible to find a replacement and info online is scarce. The fitting I found that works is Powercraft 39106, not an exact fit replacement, but it comes out of the steering box at 90 deg and is easily made to work. If you go to a parts store it will be listed for an '89 Jeep Grand Wagoneer. O'reilly's had this part for $3.99, add a new hose and fluid and you are up and running for under $20.00.
Note: this was for an '89 Wrangler Carb'd 4.2 w/ manual trans
Jax89Jeeper is offline
post #2 of 8 Old 08-12-2011, 12:29 PM
92 Green YJ
92 Green YJ's Avatar
ditto that! I had the same issue when I replaced my steering box. All the pars stores tried to just give me a regular rubber hose. Finally found that Napa had the correct part with the correct fitting and metal line attached to it. IIRC it was about 10 bucks for the part.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #3 of 8 Old 08-12-2011, 01:55 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I actually replaced mine with a gas line I found on the shelf at Napa. It had a long steel tube that I cut and bent to fit. It was around $5, so I thought I'd give it a try.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #4 of 8 Old 08-12-2011, 01:56 PM
iowajeepers
Fittings from a XJ steering gear also work for a 94 Wrangler.
1994 YJ, 2004 WJ, 1976 C3, 2015 Slingshot, 2001 ZX6r
iowajeepers is offline
post #5 of 8 Old 06-17-2013, 10:28 PM
rambo3489
Thank you guys for this info. Much appreciated.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #6 of 8 Old 06-18-2013, 03:31 AM Thread Starter
Jax89Jeeper
Glad it helped.
post #7 of 8 Old 06-18-2013, 07:56 AM
Berniebikes
Plain rubber line and a hose clamp work just fine. The return line has no pressure on it.
Berniebikes is offline
post #8 of 8 Old 06-18-2013, 04:06 PM
rambo3489
It's the end fitting I broke. You can't find that anywhere.
<a href="
THE YJ MY WAY</a>
