YJ Power Steering Gear Question - JeepForum.com
post #1 of 1 Old 08-12-2013, 03:06 PM Thread Starter
beaver24
I have an 89 YJ that I did a 4.0 conversion with a 99 XJ engine. Because of the bracket locations I am using an XJ power steering pump with my stock YJ gear. Since the conversion my power steering has seemed tight but it worked. I replaced the pump thinking I may have gotten a bad one and it was still fairly stiff. Yesterday the power steering died completely. I have checked and cleaned the lines and they are clear. Could a bad gear cause this? I always thought that a bad gear would cause more wobbly or floating steering not just tight steering. I don't see any signs of leakage from the gear. When I look in the reservoir should I see the fluid moving, because it appears to be still with the engine running and wheel turning? Could the piston inside the gear be clogged or dead? I have no problem swapping the gear I am just wondering if I am getting crap parts from Advance and the pump isn't strong enough for the gear and swapping it would be a waste of time and money.
89 YJ 4.0 Conversion 99 XJ, 2in BDS, 1" Schackle,31 x 10.5 tires, Herc'ed
beaver24 is offline
