yj plus snow? - JeepForum.com
post #1 of 19 Old 09-25-2013, 09:06 PM Thread Starter
Haggerty
yj plus snow?
so ive read on here that if not equipped right jeeps are not the best in the snow. My other vehicle is a 97 ranger regular cab short box 5spd, so im used to a fairly light 2wd short wheelbase vehicle in the snow, i put 250# in the back and i can just fine in a michigan winter. But i think it would be fun to have a 4x4 this winter for the 1st time (i have driven 4x4 in the snow and know it wont help me stop, just never owned one) i searched the forum and no one has said anything about putting 75-100# in the "trunk" do you think it will help, or just help spin me around faster when i slip and slide. ive had that happen in trucks. fyi the jeep is open in back with a locker up front.
thanks
Haggerty is offline
post #2 of 19 Old 09-25-2013, 09:11 PM
superj
It should help. People have mentioned doing that a couple of times and the cj guys talk about doing it also
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 19 Old 09-25-2013, 09:38 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Usually a hard top is enough weight but the short wheel base4x4 should be fine on its own.
Luck Favours The Prepared
Anticanman is offline
post #4 of 19 Old 09-25-2013, 09:47 PM Thread Starter
Haggerty
i have a soft top, and i guess what im worried about is not when im in 4x4, its when im in 2wd, because with the locker i cant be in 4x4 all the time, and the roads get patchy ice and snow blown on it
Haggerty is offline
post #5 of 19 Old 09-25-2013, 10:44 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's why you're able to shift on the fly at any safe speed
post #6 of 19 Old 09-25-2013, 11:48 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I have never had a issue on my Soft top equipped TJ with front and rear lockers, Or my 95 YJ with Front and rear lockers with a hardtop.
I dont have issues with my XJ, And I dont expect this yj to have issues either
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 19 Old 09-26-2013, 12:07 PM
GrantYJ
Mine has always been great in the snow. I've had weight in the back as well as running empty and haven't noticed much difference (I've always run soft tops).
Tires will make more of a difference than anything else. I'd be a little concerned about the locker. I've never run one in snow for that reason.
On ice, all bets are off. We get nasty ice storms every few years and it's never a good time. That being said, I still prefer the Jeep for ice driving.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #8 of 19 Old 09-26-2013, 02:23 PM
goodwrenchdave
I'm in the snow belt. We have real snow winters here. My jeep becomes a seldom used toy in the winter...who am I kidding...it's a toy all year. I'll drive a car mostly in the winter as I hate surprises. Jeep cj/yj/tj are just horrible at stopping in snow/ice. Haven't driven a jku in snow so can't comment, but probably more stable. If you really have to drive it as a DD then put thin winter studded tires. That's what a lot of jeep owners do around here. "bubble" tires are only good for very deep snow where you want to float.
Your advantage is that you already come from a "slippery" vehicle, so the adjustment will be easier. Small pickups are horrible too due to light weight but at least they have the wheelbase to prevent spin-a-round and few hundred pounds in the back helps.
Don't really think weight will help as sometimes there is at least 150-200 pounds of snow on vehicle and doesn't seem to have better stopping . It's the wheelbase that's the handicap. Try it....Bag of sand is a couple dollars
As for soft top in winter...I don't want to even think about it.
goodwrenchdave is offline
post #9 of 19 Old 09-26-2013, 05:58 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Canadians are so hard core.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luuca is offline
post #10 of 19 Old 09-26-2013, 08:31 PM
rambo3489
It's a horse a piece. Yes a YJ isn't the best vehicle for high speed on packed/icy surfaces. For that you want to look into an AWD audi or something fancy. But good luck with that thing in a drift or anything more than 6". If you get "real" snow you shouldn't be concerned about 2wd. I say me a man and get a JEEP. It will handle like a dream compared to a 2wd ranger.
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #11 of 19 Old 09-26-2013, 10:48 PM
Firefyter-Emt
A Jeep in 4wd with good tires will get you where you want to go... if done slow! What get's the old cheeks clenching is that Jeeps don't fish-tail, they go spinning off the road like a top! Be careful with the high speed stuff and take it easy, but the best advice is to remember if that back end gets loose.... you are not likely to get it back, there is just not enough wheelbase! I would skip adding weight, with such a light vehicle, if you need traction at the rear, just toss it in 4WD.
Firefyter-Emt is offline
post #12 of 19 Old 09-28-2013, 03:32 AM
jred
I'm so glad I live in the south
jred is offline
post #13 of 19 Old 09-28-2013, 03:11 PM
cojab
Oh h e double hockey sticks, it isn't that bad!!!!
The ice can be a little tricky especially with wider tires. In light snow and ice I usually take my F250, in deeper snow I'll take my Jeep any day over my pick up. My driveway is almost 1/2 mile long and when it drifts (1 to 2 feet regularly) my Jeep is the only thing that stands a chance of getting up it.
Otherwise I get up the driveway as far as I can, walk from my vehicle to the shop, get the tractor and start plowing!
cojab is offline
post #14 of 19 Old 09-28-2013, 04:10 PM
Reno72
My jeep always handled good in the snow, just depends on how deep, what kind if tire, your ability. In ice or up to about 8" nothing beat my Chevy Express Van AWD with BFG AT's, thing was solid even in a ice storm
Reno72 is offline
post #15 of 19 Old 09-28-2013, 05:25 PM
Shenandoah
Just slow down and enjoy the ride. If you want to drive fast in the snow, your Jeep won't do well
But, it will get you there if you slow down.
Turn a wrench, save a tree
Shenandoah is offline
