yj park and tail lights fuse - JeepForum.com
post #1 of 5 Old 08-28-2010, 11:08 AM Thread Starter
awjdonald
1994 JK Wrangler
my tail lights and dash light fuse keeps blowing would that mean its shorting somewhere anyone else have this problem any areas where it could be shorting
awjdonald is offline
post #2 of 5 Old 08-31-2010, 08:10 PM Thread Starter
awjdonald
1994 JK Wrangler
any help
post #3 of 5 Old 08-31-2010, 08:13 PM
jsawduste
2006 YJ Wrangler
My guess would be somewhere along the wires.
jsawduste is offline
post #4 of 5 Old 09-01-2010, 07:06 AM
Que89YJ
You have a short. Disconnect the tail lights and you will probably find corrosion on one of the connectors.
Que89YJ is offline
post #5 of 5 Old 09-01-2010, 07:08 AM
Que89YJ
You can use a bulb and a couple wires in place of the fuse to figure out where the short is. The bulb will dim when you find the short. It will save you a bunch of fuses and with a long enough wire you can work on it and look at the light at the same time.
Que89YJ is offline
NO tail, park or dash lights! JohnOBrien TJ Wrangler Technical Forum 11 01-24-2009 03:08 PM
Blowing fuse - 20 amp tail/park kharmajavah YJ Wrangler Technical Forum 1 11-11-2008 07:10 AM
tail lights not working correctly, passesnger side tail is dim. kbarwall TJ Wrangler Technical Forum 2 08-19-2008 09:22 PM
no tail/park/dash lights HELP snofrog TJ Wrangler Technical Forum 2 02-12-2008 04:42 PM
Tail lights not working ( hbl, switch, fuse and relay) JESSETHELJ TJ Wrangler Technical Forum 1 09-03-2006 12:48 AM
