YJ overheats in 4-Low ONLY - JeepForum.com
post #1 of 14 Old 09-01-2011, 12:18 AM Thread Starter
digizure
I can't figure this out. My Jeep keeps overheating when it is in 4-Low. It would not overheat in 2 wheel drive. I replaced the thermostat, water pump and even had the head resurfaced. The radiator is a year old so I'm thinking, it is either the radiator or the block. What do you guys think?
M
digizure is offline
post #2 of 14 Old 09-01-2011, 12:21 AM
Desert_Rampage
1991 XJ Cherokee
Possible fan clutch getting weak??
Desert_Rampage is offline
post #3 of 14 Old 09-01-2011, 12:38 AM
moonshinefuel
Beat me to it. That was my first thought.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #4 of 14 Old 09-01-2011, 12:48 AM
Desert_Rampage
1991 XJ Cherokee
A simple Fan Clutch test is to: Take a piece of tape between one of the fan blades and the shroud. (Masking tape works great.) Start the engine. If the fan can break the tape, clutch is good. If not, then it's time for a new one.
post #5 of 14 Old 09-01-2011, 01:01 AM
mike_breaker_5
clean your radiator. lol
just another guess but if your in 2wd ima guess your driving on the road. if your in 4lol then your not moving very fast at all. lol
so my first step would be to spray the mud and leaves out of the radiator fins (or ac condenser if it's still there), and try again. if that fails to help, maybe a simple flush would help also.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #6 of 14 Old 09-01-2011, 05:12 AM
Louie4
I agree with all these guys, fan clutch. I had the same issue as you and I ended up putting a Taurus electric fan in after going through 4 fan clutches. I also found out I had no wire in my lower radiator hose to keep it from collapsing under high rpms, so I made one out of a stainless steel welding rod and now my engine runs cool.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #7 of 14 Old 09-01-2011, 08:11 AM Thread Starter
digizure
Thank you for bringing up the fan. I should have mentioned this in my first post... I do have an electric fan. I believe it's a 16 inch.
digizure is offline
post #8 of 14 Old 09-01-2011, 08:28 AM
Que89YJ
4wd low isn't any different then 4wd hi or 2wd as far as cooling goes. It's about how hot the motor is getting and how much cooling capacity you have. Since you have gone through so much I assume you have been having the issue for a while and have started throwing everything at it. Is the electric fan you are using a Taurus fan? Is it on low speed setting? Does it run hot in the 4wd high? I would flush the cooling system with a flush kit to start with.
Que89YJ is online now
post #9 of 14 Old 09-01-2011, 08:50 AM
Old4X
1990 CJ7
Is this in addition to or instead of the belt driven fan?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #10 of 14 Old 09-01-2011, 09:05 AM Thread Starter
digizure
I removed my mechanical fan. My electric fan is from Flexlite (I think that's what they're called) and there is only one speed.
digizure is offline
post #11 of 14 Old 09-01-2011, 09:24 AM
Old4X
1990 CJ7
Probably not a high enough CFM. Add another or put the mechanical fan back on, they work.
Old4X is offline
post #12 of 14 Old 09-01-2011, 09:34 AM
Que89YJ
Pull the flex and put a Taurus on. It moves more air then any aftermarket or a mechanical and you are already setup for the electrical fan anyways. Is the fan running on full when you over heat? I would still start with a good flush but as mentioned you could just not be pushing enough air and the Taurus fan can be found in any scrap yard for under $50.
post #13 of 14 Old 09-01-2011, 10:24 AM
mike_breaker_5
i have read a thread or 2 about e-fans from flex-a-lite. most common problem is they spin at 10.4 million rpms but have little to no pitch to the blades moving little air over the motor.
also is it spinning the right direction? you can actually make an e-fan spin the wrong way by wiring it in backwards.
post #14 of 14 Old 09-01-2011, 03:59 PM
Louie4
Originally Posted by Que89YJ
...and the Taurus fan can be found in any scrap yard for under $50.
$16.00.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
1994 2.5L YJ overheats at high RPM BuckarooBanzai YJ Wrangler Technical Forum 9 06-11-2011 03:00 PM
Overheats digizure YJ Wrangler Technical Forum 44 07-19-2010 05:01 PM
Engine overheats at low speeds Jeepdrivinmid TJ Wrangler Technical Forum 10 02-11-2009 07:02 PM
89 YJ overheats at idle gbentley89YJ YJ Wrangler Technical Forum 7 07-14-2008 09:22 AM
2001 TJ overheats guy_braverman TJ Wrangler Technical Forum 10 11-25-2005 05:18 PM
