Is yj ome 2.5" installation correct? - JeepForum.com
post #1 of 8 Old 06-09-2010, 07:12 PM Thread Starter
JEDPAGE
So just picked up my YJ from the shop with a NEW OME 2.5 Suspension system installed but it seems that it's not level. The rear is higher than the front and I noticed that the're 4 leaves in the front and five leaves in the back.
Was this installed done correctly?
Thanks for your help.
JEDPAGE is offline
post #2 of 8 Old 06-09-2010, 10:05 PM
sprowley
Depends on what duty springs you have in the rear. Heavy duty springs with no or soft top will do that because they're meant for heavier loads, so unloaded they'll arch more. Load it down with a seat, some gear and a hard top and it will probably level out.
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #3 of 8 Old 06-09-2010, 10:25 PM
dodger889
First welcome to the site. Second what engine do you have.
Please fill out your profile.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 8 Old 06-09-2010, 11:20 PM
CALWATERBOY
Soooooo, how's she ride?
CALWATERBOY is offline
post #5 of 8 Old 06-10-2010, 05:06 AM
YJake
Mine may be slightly higher in the rear (heavy duty both ends) because there's much less weight back there. I loaded 4 transfer cases back there one day and it leveled out nicely not to mention the smooth ride!
If you run a soft top or no top with little/no gear in the back the rear will always be slightly higher.
Also, welcome to the forum! Please fill out your Jeep's profile
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #6 of 8 Old 06-10-2010, 07:13 AM
jbolty
jbolty's Avatar
ditto. ^^^
I put heavy duty on all 4 corners and after adding a heavy winch bumper in front and a tire swing with a 35 in the back along with 2 jerry cans it leveled right out and rides great. more flex than I know what to do with.
jbolty is offline
post #7 of 8 Old 06-10-2010, 08:54 AM Thread Starter
JEDPAGE
Guess It's Right
Thanks for the replies. After further research I've determined it was done right. It's got CS014F in the front and CS036R in the rear. It'd seem that you'd want another leave up front with the weight of the engine.
The ride is great much better than the worn out stock that I had. Well worth the money.
JEDPAGE is offline
post #8 of 8 Old 06-10-2010, 09:04 AM
CALWATERBOY
Thx for the feedback!
Mine arrives in a couple o'weeks....
Correct gears for 32" tires --4.11 or 4.56, or does it matter? brjeep TJ Wrangler Technical Forum 6 08-01-2009 06:41 AM
Correct Speedometer Gear for 32" tires w/ 4.10 gears 01TJfuntime TJ Wrangler Technical Forum 2 02-28-2009 01:42 PM
correct speedo gear for 33" tires? duality TJ Wrangler Technical Forum 4 01-22-2008 02:17 PM
how important are the "correct" vacuum hoses? 9erHIGH YJ Wrangler Technical Forum 1 05-20-2007 07:04 PM
How to do an absolutely correct 2" lift? Mr. Tarmac TJ Wrangler Technical Forum 33 02-22-2007 05:37 AM
