It could be that you have a Canadian model with Metric gauges. I think the units for them are MPa, not psi. Do you have a Kph speedometer and a temperature gauge in degrees C?
Other than that, the pressures sound ok, just as long as it's above 0 at idle, and halfwayish when driving. Depends on the viscosity of oil, temperature, and if your sending unit is good too.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
