YJ Oil leak - JeepForum.com
post #1 of 12 Old 04-16-2013, 07:51 PM Thread Starter
ckahl2
YJ Oil leak
Ok, so last night I was driving back home on the highway and noticed my oil pressure dropping fairly quickly. I pulled off the highway to a gas station and discovered a small pool of oil under the jeep. I was still about 80 miles from home so I bought some oil and put about half a quart in. I noticed that the oil pressure stayed roughly the same and didn't drop after that as long as I kept the engine reved at around 25-3000 and made it home with no problems, however there was a noticeable leak coming from the jeep. I parked it and checked this morning and it looks like the oil is coming from a few different places around the pan possibly. I'm pretty much a novice when working on engines, but it seems to me like the oil pan gasket s*** the bed or the pan itself rusted out. Any other thoughts on what the problem could be? And also what It might cost to have it fixed at a shop or the stealership? (Can't work on cars in the school parking lot unfortunately). The Jeep is a 1992 2.5 liter with 60,000 miles on it if that helps. Thanks!
ckahl2 is offline
post #2 of 12 Old 04-16-2013, 09:47 PM
jokerchief462
Find a good shop or someone you know who can do the work. Yes it could be a pan gasket but oil leaks are funny. Gravity drives the oil to the ground and the fan and wind in the engine bay drives the oil to the rear of the engine./ So it will have to be cleaned up too find the exact leak and may not be the pan. So find someone you trust and get a written estimate first.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 12 Old 04-16-2013, 09:57 PM
bigbossd1030
Screw the shop, nobody you know has a garage? Depending on where it is coming from its probably a very simple job. Even if it is a more difficult one, the shop will charge you a crap ton to do the work. Not worth it. Buy a buddy some beer to help you and fix it yourself. Start by finding the leak. Keep an eye on the rear main seal, this one means you have to drop the tranny. Also check the valve cover and as you said oil pan. Shop is always a last resort in my books.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 12 Old 04-16-2013, 10:33 PM
rubinscube
Easy fix.get a gallon of simple green.wait till engine is cool.spray down with cleaner.wait 1 hour.rinse & repeat.next run in place and you should see where the leak is.
"It's not a failure, just a change of objectives."
1988 YJ Carter BBD 4.2 Nuttered
rubinscube is offline
post #5 of 12 Old 04-17-2013, 07:04 AM
UZI4U
SCREW the school! You pay them to accommodate you. Do what you need to do and tell them to get bent...I would.
MCLMM
UZI4U is offline
post #6 of 12 Old 04-17-2013, 07:27 AM
pete1991YJ
If its leaking that fast then I doubt its just a pan gasket. Those tend to be a slow seep. Like others have said, clean the engine off so you can see where its coming from. Start it and let it run for a few minutes. Then look for it. Beware the fan could blow it around from where its actually leaking.
I would immediately suspect the oil pressure sender or the filter itself. The rear main seal doesn't have any pressure on it the way a chevy does, but it *could* leak at a good rate.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #7 of 12 Old 04-17-2013, 07:38 AM
Kuntryboy816
Kuntryboy816's Avatar
x2 on what BigBoss said...
You'd be surprised how simple it is to work on a Jeep. Try to at least locate the source of the leak first by cleaning the engine. Once that's done post back up for help. Valve cover gasket and oil pan gasket are both very easy fixes. The rear main seal is more involved but can be done with simple hand tools and time.
@Rubinscube: I want to steal your signature!
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #8 of 12 Old 04-17-2013, 05:04 PM Thread Starter
ckahl2
Alright, I took everyone's advice and cleaned up under the Jeep, put a bit more oil in, and turned it on to see where the leak was coming from. When the Jeep is running it leaks at about a drip per second from the left edge of the oil pan (left edge looking up at the pan from under the vehicle), which is also right below the oil filter, so at this point I'm starting to think its the filter. I can't see any drips coming directly off the filter, but it could be running down the block to the oil pan where it's dripping, right? If it's the filter, would it be as simple as replacing it? Could it be anything else? (I still think the gasket is a possibility, but I'm new to this, haha). Also, to everyone who suggested I do the work myself, I would love to be able to do that, but I have a very limited tool box at school, don't have a place to go off campus and work, and I don't know anyone in the area (I go to school in Raleigh, but I'm from the Boston area).
ckahl2 is offline
post #9 of 12 Old 04-17-2013, 06:34 PM
rubinscube
I had a similar drip by the filter.turns out iy was the distributor seals.just in case check it out and good luck.
post #10 of 12 Old 04-17-2013, 06:34 PM
bigbossd1030
Check below your distributor as well. I remember reading a post about oil coming from the dizzy, but I didn't read into it. It as you know is above your oil filter. So it's at least in close proximity to the filter. Plus see if you give your oil filter a turn to see if it tightens a bit and stops leaking. Well at this point you will only need a small amount of tools to fix this leak anyhow. It's not the rear main or anything that requires jacks and pullers. You should be able to fix this leak with a basic socket set from Walmart.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #11 of 12 Old 04-17-2013, 10:06 PM
4.7stroker
Just above the oil filter you will see the oil pressure sending unit, it has a single wire going to it. The oil sender can spring a leak and is a common failure mode. It is cheap and easy to replace. Just start the motor and look with a flashlight to see if it is leaking.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #12 of 12 Old 04-19-2013, 01:03 PM Thread Starter
ckahl2
Alright, I talked to someone who looked at the jeep and theres good news and bad news. The good news, everyone here was right. The bad news, that means i have 4 leaks to fix. The valve cover, RMS, oil pan gasket, and the oil pressure sending unit are ALL leaking. Thanks for everyone's help in figuring out what it was!
ckahl2 is offline
gasket , help needed , oil pan , rear main seal , rms
