YJ not consistently starting. Timing problem suspected. - JeepForum.com
post #1 of 7 Old 10-20-2011, 12:29 PM Thread Starter
91YJWrangler
Hi All,
I have a 91 YJ 4.0 L with 150,000 miles on it that has not been constantly starting. The engine turns with no problems and when it does start it runs great. I treated the fuel thinking that it could be bad fuel after sitting for months and the problem persists. I have tried starter fluid which seems to work some times but not all the time. When it does not start, if I let it sit for a while it will start again. The reason that I am suspecting the timing is that I have seen smoke, or more likely exhaust coming from the intake. I'm hoping to diagnose and fix the problem without taking it to a shop.
Thanks for your help!
Ian
91YJWrangler is offline
post #2 of 7 Old 10-20-2011, 12:33 PM
tdewit
Have you removed the distributor cap and inspected/cleaned it? What about the HT leads, are they in good condition?
tdewit is offline
post #3 of 7 Old 10-20-2011, 01:56 PM Thread Starter
91YJWrangler
What are HT leads?
post #4 of 7 Old 10-20-2011, 02:12 PM
tdewit
High Tension or spark plug leads.
tdewit is offline
post #5 of 7 Old 10-21-2011, 02:52 PM
Brown Dog
Vendor
Brown Dog's Avatar
The timing on a 91 is controlled by the computer; you can't adjust it. I would go with what tdewit said as a first step.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #6 of 7 Old 10-22-2011, 01:01 PM Thread Starter
91YJWrangler
The HT lead going to the distributor is totally shot (see pic). I'll replace the leads and see if that solves my problem. Thanks for the advice fellas. You might have just saved me hours of time! I'll post after replacing the leads.
post #7 of 7 Old 10-24-2011, 06:25 PM Thread Starter
91YJWrangler
Changed the HT leads and she is back in action. Again, Thanks for the advice!!!
2.5 engine timing problem Trytan74 YJ Wrangler Technical Forum 4 07-19-2009 08:51 PM
Check engine light on, suspected misfire...Already serviced 2 days ago for this... Mudpuppy09 TJ Wrangler Technical Forum 16 04-16-2009 08:05 AM
Clockspring suspected dead Wrangler_91 TJ Wrangler Technical Forum 6 09-02-2008 10:46 AM
91 YJ New computer & still not starting consistently redrcks YJ Wrangler Technical Forum 8 06-19-2008 08:30 PM
Is mt timing the problem? ElvisV04290 YJ Wrangler Technical Forum 4 03-13-2007 09:54 PM
