#1 | |
YJ Not charging??? Fusible Link???
I changed my starter and when I replaced the wires on the solenoid and hooked up the battery I got a spark. I figured out that one of the wires I hooked to the solenoid was actually a ground. What baffles me about that is it looks like it is also a fusible link, but when I hooked it to the chassis no more spark. I am pretty sure one of the fusible links is bad. The alternator worked fine before the starter swap and suddenly doesn't. Is it possible to replace all the the fusible links with regular breakers (possible in a fuse block on the firewall)? What is the best way to check the fusible links?
Thanks
#2 |
Best way to test the fusible link is with an ohm meter. With the battery disconnected, you should have continuity from the red wires on the alt to the positive battery cable (common point is at the starter relay). If not, then it is bad. There is another link from the ignition switch (red), that should also ohm out the same way. The links are color coded for their size. Sounds like the brown one is bad from the alt preventing any charge from getting to the battery.
#3 |
Can I just replace them with regular fuses?
#4 |
With some extra wiring and fuse holders you could, but I don't know that it would be worth the effort. If you were blowing them on a regular basis, then I would say go for it. If this is the first time, then I wouldn't bother. They are relatively cheap and not hard to replace.
#5 |
I know this is a newbie question, but I am a newbie. How exactly do I replace them? I really can't see in there very well.
#6 | |
#7 |
Thanks alot I will check that out.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
