Yj No spark after random engine shut off. - JeepForum.com
post #1 of 5 Old 04-11-2010, 12:37 PM Thread Starter
Ryn109
Was gonna drive my jeep to work one morning it started up and ran for like 3 seconds then shut off with no sputter. I tried to crank it over and nothing. When i got home from work I was getting no spark. I plugged in my other coil I had and nothing. I plugged in my other CPS sensor i had from my old transmission and still nothing! 1992 yj, Engine is 4.0 manual tranny. I posted similar post on NwWheelers. Looking for some more insight to my problem. Thanks for any input, Ryan.
Ryn109 is offline
post #2 of 5 Old 04-11-2010, 01:01 PM
roccomonte
does your check engine light turn on when the key is on?
roccomonte is offline
post #3 of 5 Old 04-11-2010, 01:04 PM
88YJtoCJ
I would see if you get spark ON the coil, not at the plugs. Then work your way through your ignition system backwards from that point...
My money is on your ignition switch.
88YJtoCJ is offline
post #4 of 5 Old 04-11-2010, 01:09 PM Thread Starter
Ryn109
Getting 12volts at coil and about 5 at the distributor. Any way to check ignition switch?
Ryn109 is offline
post #5 of 5 Old 04-11-2010, 01:10 PM Thread Starter
Ryn109
No check engine light.
Ryn109 is offline
Random shut down, dropped cyl(s) P340 code rlk_99 TJ Wrangler Technical Forum 13 03-31-2010 06:36 PM
engine shut down ? bjeeper23 TJ Wrangler Technical Forum 2 10-29-2008 08:24 PM
Engine wont shut off oneoffed YJ Wrangler Technical Forum 5 08-21-2008 08:20 PM
engine shut off? Spigger73 YJ Wrangler Technical Forum 0 01-10-2007 08:10 AM
Help!!2.5 yj overheating after engine is shut off ddavis2754 YJ Wrangler Technical Forum 5 05-29-2006 05:40 PM
