YJ nightmare! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ nightmare!
Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock
Unread 07-15-2011, 05:42 AM   #1
hotrodsdad
YJ nightmare!
my son and i have a 90 YJ that has been nothing but electrical H*** ever since we bought the thing. We have replaced everything BUT the wiring harnesses including the ECU! The problem usually has been no ignition, but now we have no power to the fuel pump. I jumped a 12 volt source to the fuel pump wire, got fuel pressure, had ignition fire, but still had to pull the D*** thing home. I suspect that the same power that was missing from the fuel pump is the same source to the TBI, but have no clue how to troubleshoot any further. If anyone has any suggestions or similar problems, I would appreciate any help!
hotrodsdad is offline   Reply With Quote
Unread 07-15-2011, 07:24 PM   #2
NonRubicon
What do you mean by "everything"?
List all the components that you have replaced/checked. It will be helpful in narrowing down the problem sooner without suggesting things that you've already done.
In general. when dealing with electrical issues - Start at the battery.
NonRubicon is offline   Reply With Quote
Unread 07-15-2011, 08:32 PM   #3
jonpin
possibly the connection in the steering column well mine are messed up feels like teeth are missing on a gear ,thought it was the tumblers but it wasnt it was the workings inside the column hosed it all with wd40 to make sure it was gumed up ,but sometimes I had to turn it off and on acouple times to get the fuel pump to come on "works better after the wd40 maby cleaned a contact or loosend something sticky up". dont know if this helps but just tossing an idea out there.
jonpin is offline   Reply With Quote
Unread 07-15-2011, 11:07 PM   #4
ChrisNukemYJ
I had the same problem. Did you replace the bulk head connector? If not do it.
_____
/| ,[___],
|--L -[]lllll[]-
()_) ()_)-o-)_)
ChrisNukemYJ is offline   Reply With Quote
Unread 07-15-2011, 11:10 PM   #5
Ripper3494
AUTASTIC
Ripper3494's Avatar
welcome to yjs, i had the same problem, the po had directly wired my fuel pump to an ignition wire which is all fine and dandy untill it breaks and i cant follow it back, i replaced the entire harness... too much trouble
build thread:
http://www.jeepforum.com/forum/f22/9...-spud-1218315/
1997 ZJ limited - BONE stock
http://www.jeepforum.com/forum/f12/a...te-up-1301614/
http://www.jeepforum.com/forum/f12/t...ation-1417686/
RC vs BDS
http://www.jeepforum.com/forum/f12/r...s-bds-1461555/
Ripper3494 is online now   Reply With Quote
Unread 07-15-2011, 11:54 PM   #6
Sawicki4wd
I just had the same thing happen to me. It took me 3 weeks and searching for a short or a shot relay to finally discover it was a bad ECM or ecu what ever you call it
Sawicki4wd is offline   Reply With Quote
Unread 07-16-2011, 12:25 AM   #7
monkeyhouse
There are two great sources for this type of problem, one was a writeup by 5-90 which i have not been able to find and another was a thread response by que89yj. I will try to find the links and post back, but search and see what you find as well!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline   Reply With Quote
Unread 07-18-2011, 06:11 PM   #8
hotrodsdad
we had to change the ECU AGAIN!! it's been running ok since then, except for the fuel gauge and oil pressure gauge both were pegged out when the switch on and the engine off we narrowed that problem to no ground for the gauges at the cluster wiring connection. we made our own ground temporarily until we can trace out the wiring harness and find where it comes from
Unread 07-18-2011, 07:41 PM   #9
schitzangiggles
King of Mac-istan
schitzangiggles's Avatar
It never ceases to amaze me the number of strange issues a bad (especially a few bad) grounds will cause. It has become my default setting now for nearly any electrical issue to check the grounds before anything else.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote
