YJ Newb needs some help - JeepForum.com
post #1 of 11 Old 04-29-2011, 03:22 PM Thread Starter
Sybenn
Hey guys, I just moved to Colorado Springs from the UK and the first thing I did was get myself a Jeep, we dont really have them in the UK.
So I got a 1990 YJ, 2 inch lift sitting on 31's and I am having issues with the idle. When I am coming to a stop the idle drops down to about 500 rpm and stalls. Yet when it is sitting and I adjust teh idle speed it can go upto 1000 rpm. The Rpm speed is constantly flickering from 600 to 1500 RPM.
Looks liek all the emissions stuff has been bypassed or dismantled, but it has a tiny little air filter on the carb ratehr than the big black housing that it should have.
I also noted that the accelerator levers at the side of the carb (where the adjustment screws are) the outer lever seems to have a significant amount of play before it moves the other lever, should there be any kind of play at all?
As you can tell, I am new to this, also I am British, sorry, so need some advice with this great vehicle!!
Sy
Sybenn is offline
post #2 of 11 Old 04-29-2011, 07:27 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Sy
My memorry is a bit foggy but idle isssues can be caused by a bad/leaky accelerator pump. Make sure the carb is not loose on the intake. What make/model carb on this engine?
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
post #3 of 11 Old 04-29-2011, 08:56 PM
nembudonna
I had a problem with mine dieing out evey time I stopped and the Idle would fluctuate and It turned out to be the booster on the power brakes was leaking. Don't know if that's your problem just telling you. Also it would be helpful if you filled out your profile. Lots of luck
nembudonna is offline
post #4 of 11 Old 04-29-2011, 09:06 PM
4.7stroker
Don't worry I am bi lingual, I speak English and American. Grew up in Berkshire and joined the US Air Force.
Post up some pics so we can see what you have on her. This will help in the diagnosis of the issues.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #5 of 11 Old 04-30-2011, 12:12 AM Thread Starter
Sybenn
Lol at Dwayne. You speak yankanese and English that's awesome. I'm a Yorkshire lad myself. Thanks to everyone who replied. I will get some pics uploaded on Sunday so you can see what I got. Anything in particular I should upload? If not I'll post pics of the carb and accelerator works. I think it's a stock carb. Willis??!? BBD.
Sybenn is offline
post #6 of 11 Old 04-30-2011, 07:53 AM
4.7stroker
If it is a stock carb then idle issues are a common problem there is a fix for that.
http://www.jeeptech.com/engine/carter.html
I would also throw a rebuild kit on it, they are cheap and the 20 yo carb will probably thank you for it.
There are 4 major things you can do to make it run so much better.
Nutter,
Team Rush,
Throw that carter away and install a Motorcraft carb.
Remove all of the crap that is no longer needed after those mods.
All are covered on the web and in this forum.
Dwayne
[url]
[url]
post #7 of 11 Old 05-04-2011, 10:08 AM Thread Starter
Sybenn
hey guys i got those pics to show you of the throttle
but how do you post pics on here?
Sybenn is offline
post #8 of 11 Old 05-04-2011, 10:11 AM
giggityjeeper
Nutter,
Team Rush,
Dwayne
not stock byt the sounds of it.. the little air filter would sugest a Weber.... sounds liek a bad choke or a vac leak somewhere....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #9 of 11 Old 05-04-2011, 10:26 AM Thread Starter
Sybenn
I think it is stock its the 2BBL type here is a link to the pics of it all
https://picasaweb.google.com/lh/sred...3AE&feat=email
where my finger is you can see on the accelerator part that has a lot of play, the second pic with my finger is the underneath of teh accelerator rod/cable and it looks to me as if springs should be there.
there is also a round thing under where the windscreen wash bottles are, what is that? It looks lik eit has a breather pipe coming out of it and looks like heat has melted the connection to whatever that is on my wheel arch lol
Sorry Noob speak!! But just found that this morning
Sybenn is offline
post #10 of 11 Old 05-04-2011, 05:50 PM
raynmaker
Welcome to the springs. Hit me up if you want some help. I have messed with all that stuff on mine. I'm hopefully doing the sye this weekend, you could swing by, have a beer and we can look at yours.
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #11 of 11 Old 05-05-2011, 11:20 AM Thread Starter
Sybenn
Yeah definately will hit you up pm me your number. May not be able to make it this weekend as working Saturday and I HAVE to replace my u joints on the axles. They are wobbling like crazy. Noticed a shift motor on the right axle. Guess I can just use silicone/corking to Renew the seal when I pull the axle out? In fact I have a joint press will even need to pull the axle out?
Get in touch though as a beer sounds good
Sybenn is offline
accelerator , carb , mixture , timing , YJ
newb help Mudzilla6661 Wrangler General Discussion 3 08-06-2009 05:04 PM
New Newb ACDJeeper Wrangler General Discussion 17 03-12-2009 02:27 PM
Im a newb. 1krzy1 TJ Wrangler Technical Forum 2 11-07-2008 05:54 PM
Hello from a Newb 4sqrlfury YJ Wrangler Technical Forum 7 10-15-2007 10:36 AM
Newb: I need help wayfastwhitey44 YJ Wrangler Technical Forum 7 09-29-2007 12:27 PM
