YJ manual transmission change - JeepForum.com
post #1 of 12 Old 03-03-2010, 02:36 PM Thread Starter
newjeepusr
I was told by someone who worked at a local lube place here in Indianapolis that in order to get all of my transmission fluid out of my car they would have to hook my Jeep up to a maching and they would pump out 8 quarts of fluid and put back 8 quarts of fluid. He went on to tell me that I could do it on my own, however it will only drain the 4 quarts out of the tranny itself, and there is 4 more quarts I can't get to. Is this true or false? Should I just pay the labor and have them do it? or do it on my own?
newjeepusr is offline
post #2 of 12 Old 03-03-2010, 02:47 PM
1998zj
If you have a manual they are full of sheite. Just pull the drain plug, empty it and dump 4 quarts of 10w30 in it. You are good to go.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #3 of 12 Old 03-03-2010, 02:50 PM
93jeepyj
Yea that sounds like they were thinking of an auto tranny where fluid would be "stuck" in the torque converter.
93jeepyj is offline
post #4 of 12 Old 03-03-2010, 02:51 PM
TheDustMan
You have the AX-5, right? The fill plug is up on the passenger side of the transmission. It takes a umm... 17 mm wrench or something to remove it. The drain plug is down towards the bottom. Don't remove the upper plug with the torx head, that one isn't for removal.
An easy way to fill the transmission is to remove the shifter assembly and fill it through the top until it starts trickling out of the fill plug hole, piece of cake.
TheDustMan is offline
post #5 of 12 Old 03-03-2010, 02:52 PM
muddy93
1987 FSJ Wagoneer
The guy you talked to either thought you had an auto, or doesn't know what he's talking about.
just pull the drain plug, and as TheDustMan mentioned, it's easier to fill it by removing the shfiter.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #6 of 12 Old 03-03-2010, 02:54 PM Thread Starter
newjeepusr
I shouldn't use gear oil?
post #7 of 12 Old 03-03-2010, 02:56 PM
TheDustMan
I think thats what the manual recommended but many of us use 10w30 engine oil. It warms up faster, shifts smoother, and doesn't have chemicals in it that tear up the synchronizers like gear oil does.
post #8 of 12 Old 03-03-2010, 02:56 PM
muddy93
1987 FSJ Wagoneer
Well, I'm not sure about the AX5's, but the jeep part number for the proper lubricant for the AX15's, is for 10w30 motor oil.
muddy93 is offline
post #9 of 12 Old 03-03-2010, 03:06 PM Thread Starter
newjeepusr
"An easy way to fill the transmission is to remove the shifter assembly and fill it through the top until it starts trickling out of the fill plug hole, piece of cake."
The shifter assembly on the inside of the Jeep? So I can fill the manual transmission fluid from the driver or passenger seat?
Last edited by newjeepusr; 03-03-2010 at 03:08 PM. Reason: didn't mean to type out ****
post #10 of 12 Old 03-03-2010, 03:08 PM
95greenrio
Yes, take the boots off and then pop the retaining collar out and you can pour the oil down through the shift tower.
1995 YJ Rio Grand - work in progress
95greenrio is offline
post #11 of 12 Old 03-03-2010, 03:09 PM
TheDustMan
The shifter assembly in the ****pit of the Jeep?
lol, it blanked out ****.
And yes, in the cab. Remove your shifter boot assembly and then push down on the retainer while turning it counter-clockwise (I think, might be clockwise) then once the retainer pops out, just pull the shifter assembly up and out and you'll have a nice opening where you can just add the new oil.
post #12 of 12 Old 06-16-2013, 05:48 PM
Soundy
This is a great idea, except I found it was a pain in the arse to get the boot back on :P
Soundy is offline
Manual transmission change usmarinekurt TJ Wrangler Technical Forum 4 01-10-2010 04:21 PM
Manual Transmission & Dana 44 Fluid Change nsjeep TJ Wrangler Technical Forum 13 04-09-2009 03:31 PM
Manual Transmission Fluid Change--Need Opinions!! kylebgt TJ Wrangler Technical Forum 20 12-21-2008 09:06 PM
Manual Transmission Fluid Change luk4mud TJ Wrangler Technical Forum 4 06-30-2007 09:11 AM
manual transmission fluid change question houndog TJ Wrangler Technical Forum 9 06-03-2007 06:51 PM
