YJ major rebuild - JeepForum.com
post #1 of 6 Old 07-11-2006, 07:34 PM Thread Starter
barney9393
barney9393's Avatar
YJ major rebuild
I have an 88 YJ, 4.2l, 5 speed. A few weeks ago what began as simply replacing the worn out 4.2 with a reman engine has turned into a "frame up" restoration. I only need to remove the tow hooks, the spring shackles and the rear track bar and I'll have the frame bare and ready for sandblasting. I plan on having the frame powder coated black. Two of the leaf springs were broken and I will need to start the reassembly with those. There has never been a lift kit installed and I am debating whether or not to install a 1-2 inch lift leaf springs. What do I need to be aware of to make that decision? Are there drive line considerations? I don't plan on 33 inch tires (I'm not sure the engine, transmission would put up with the bigger rubber, anyway.)
I am looking forward to reading your input. Thanks!
barney9393 is offline
post #2 of 6 Old 07-11-2006, 07:38 PM
yjing
the 4.2l will handle way more than 33's, if regeared of course. if you want 31's, 1-2 inches would have you rub-free giving you good clearance. You don't need SYE/CV with that little bit of lift.
89er 4banger
Red Jeep Club Member #360
yjing is offline
post #3 of 6 Old 07-11-2006, 08:54 PM
z71offroader
z71offroader's Avatar
sounds like a nice build! if ur guna be doing such a nice job like it sounds ur doing id put some 33s on it. the i6 will work fine with 33s. my stock i6 works great with my 35s but i did have to regear. so if ur guna end up regear or putting lockers in then 33s would be a nice way to go if not 31s with 1-2" of lift will work.
93 YJ- SOA, R.E 1.5" Leafs, Custom paint, 35x16 Boggers,15x10 97 series rockcrawlers. Diamond plated interior and exterior, Tera SYE/CV DS, Herculined Tub, Bestop, Warn Bumpers w/ 9.5ti, 8.8" rear, D30 front, both ARB's with 4:88's, Super 88, Posi-Lok, Alpine Stereo, Tuffy Security, Hella Fogs, ProComp Spots, and much more.
07 2500HD D-Max CC LB Black Ranchhand Bumpers, MBRP 5" Straight Piped Exhaust, Edge Evo, N-fabs, 305/65/18 BFGs on Black Motos, much more soon to come!
(Sold)03 Z71- 33x12 BFG Muds, American Racing Victor Teflons, K&N intake, Gibson Exhaust, Ranchand bumpers, Hypertech programmed, Hella Spots, 12" JL sub, and much more.
z71offroader is offline
post #4 of 6 Old 07-12-2006, 05:50 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Take lots of pictures! and keep a log.
Only bit of advice I can pass is get a few good books, FSM, chiltons etc. Double check the torque on every bolt. You'll be glad you did.
How much did the longblock cost you?
- Ernie
Richmond88yj is offline
post #5 of 6 Old 07-12-2006, 10:59 AM
GiggityJeep
chiltons suck
GiggityJeep is offline
post #6 of 6 Old 07-12-2006, 06:36 PM Thread Starter
barney9393
barney9393's Avatar
Reman long block through my local NAPA dealer was about $1300.00 exchange.
yo rebuild or not to rebuild that is thi question njdpb22 YJ Wrangler Technical Forum 22 12-01-2010 07:07 PM
Jeep Engine to Rebuild or Not to Rebuild booyia TJ Wrangler Technical Forum 31 10-02-2009 12:16 PM
major boo boo blamejane2 YJ Wrangler Technical Forum 5 12-14-2008 01:36 PM
Major Problem with my TJ???? GaytorHater703 TJ Wrangler Technical Forum 16 06-21-2007 06:07 AM
Major help needed noodles2049 YJ Wrangler Technical Forum 4 06-23-2006 10:40 AM
