YJ lift advice - JeepForum.com
post #1 of 23 Old 05-06-2012, 10:55 PM Thread Starter
yoyoyo109
2015 JK Wrangler
YJ lift advice
Hi everyone. i just put some nice new fender flares on my jeep after the last ones were destroyed pretty. I'm now looking at a lift kit to add to my jeep to raise it to a point where it wont hit my flares unless a spring or something else breaks. the PO said he put an inch body lift and a 3 inch lift on by adding bigger shackles but after getting under there today i think he was either lying or oblivious. I've taken some pictures so yall can hopefully help me to decide what height to get. right now i'm thinking 4 inches
yoyoyo109 is offline
post #2 of 23 Old 05-06-2012, 11:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's a half inch shackle lift and a one inch body lift.
The shackle reversal gives a little lift up front.
Luck Favours The Prepared
Anticanman is offline
post #3 of 23 Old 05-06-2012, 11:16 PM
idskot
I'm confused. Did the PO mount the shackles on the opposite side of where they're supposed to be?
This is a bad idea if this is more than a Mall Queen.
It does look like it's lifted a bit VIA shackles, but no 2" worth.
To get some more height you can do a bastard pack, or get a proper suspension lift. Do not go bigger than that BL you have right now.
idskot is offline
post #4 of 23 Old 05-06-2012, 11:55 PM Thread Starter
yoyoyo109
2015 JK Wrangler
I'd like to consider this as much more than a mall queen. and i'm really not 100% sure what the previous guy did. said he had just put in a new clutch but had it serviced a while ago and there was hardly any friction material left in it!
but like I mentioned, I figured he lied about the lift so i'm looking for a 4 inch lift kit. i've seen some on 4wd from rubicon express, skyjacker and pro-comp that are all reasonably priced i think. they come with new shocks, extra brake line. longer steering components and tie linkages as well. Is there anything else i'll need to consider? and should i reverse the shackles to factory or will they be fine like this? I'm not planning on doing some heavy rock crawling but I do enjoy going to some of the offroading parks around me and play in the mud
post #5 of 23 Old 05-07-2012, 12:05 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The three you want to buy are BDS, OME, and rubicon express. If you're looking for a couple more inches over your current setup then give a quick measurement to your rocker panels and your tire size. Then we can deduce the spring height. Then the recommendation.
post #6 of 23 Old 05-07-2012, 12:29 AM Thread Starter
yoyoyo109
2015 JK Wrangler
it will be a while until I'm able to measure the distance, but i know my tires are 33s and they need to be about 2-4 inches further away from the fender flares
post #7 of 23 Old 05-07-2012, 01:24 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That measurement is your proverbial jumping off point to determine how to gain said desired lift.
post #8 of 23 Old 05-07-2012, 10:18 AM Thread Starter
yoyoyo109
2015 JK Wrangler
alright, it looks to be about 22 inches to my rocker panels, 19 to the nerf bars and i went ahead and threw in a picture of the spring if it helps
post #9 of 23 Old 05-07-2012, 11:45 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The stock measurement is 18" with 29" tires. You have 33" tires do that's 2" and a 1" body lift and half inch shackles. That's a little over the math but your springs are pretty saggy and your tires may not be exactly 33".
To gain the desired lift I would recommend BDS 2" springs and possibly a transfer case drop if you have vibes at all. Shocks should be for a 3" lift but it's best to measure with the new springs on and flex the suspension to gain the collapsed and extended lengths.
post #10 of 23 Old 05-07-2012, 02:28 PM Thread Starter
yoyoyo109
2015 JK Wrangler
I've been looking at a Rubicon express 4 inch lift kit to get my tires plenty more clearance while at the same time getting a good amount of extra height in. I'm not sure if it comes with new shackles, but would the half inch shackle lift be an issue? And what else would I have to worry about? The kit comes with a drop pitman arm, longer tie linkages, track bar brackets and brake line extensions
post #11 of 23 Old 05-07-2012, 02:33 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's a viable option as well. I don't think you would need the track bar brackets or the track bars at all for that matter.
post #12 of 23 Old 05-07-2012, 02:56 PM
Siva283
With a 4 inch lift plus the shackles you are getting into SYE territory as well. So add an SYE kit and CV style drive shaft.
Ask me how I know...
Siva283 is offline
post #13 of 23 Old 05-07-2012, 04:29 PM Thread Starter
yoyoyo109
2015 JK Wrangler
Well the jeep came with a SYE when I bought it, I'm not sure about the cv drive shaft but it also has a lowered skid plate
post #14 of 23 Old 05-07-2012, 04:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pics of SYE and driveshaft please!
post #15 of 23 Old 05-07-2012, 05:35 PM
idskot
If you have a SYE, you have a CV Drive shaft.
idskot is offline
lift advice
Need Advice on lift kit J33Pyj YJ Wrangler Technical Forum 0 02-03-2010 03:07 PM
lift kit w/ body lift - need advice/opinion coldyj YJ Wrangler Technical Forum 13 03-24-2009 03:34 PM
Need advice on motor mount lift and body lift learfxr YJ Wrangler Technical Forum 1 07-06-2008 11:21 PM
Want lift 2006 Wrangler Rubicon Unlimited 2" to 2.5". Need lift system advice. CB3 TJ Wrangler Technical Forum 8 04-19-2007 09:44 PM
Ome Lift Advice SB99TJ TJ Wrangler Technical Forum 21 03-05-2006 08:54 PM
