yj led cluster lights + dimmer? - JeepForum.com
post #1 of 3 Old 06-26-2013, 06:27 AM Thread Starter
ufvj217
I just read a ton of threads for led replacements. Couldn't find much on if the dimmer would work or not. Is there a way to make the leds dimmable?
ufvj217 is offline
post #2 of 3 Old 06-26-2013, 11:28 AM
Old4X
1990 CJ7
Dimmer should work fine. If not it is simple to add a resistor to get whatever light level you want.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 3 Old 06-26-2013, 03:44 PM
JWELK
In general dimmers don't work on LED's. They are current activated as opposed to voltage driven like incandescent lamps. As you try and dim them, you will find some will be brighter than others. The chances of you getting a dozen or so identical lamps, is not too good. LED dimmers are not resistors, they are Pulse Width Modulators, similar to how the alternator regulator works on later model Jeeps. If you are good with a soldering iron, you can build a PWM, however, you may have some interference issues with your radio.
Soo what to do? If you just want to change the color, Sharpie indelible markers are supposed to be quite effective. I've only used red. You may also try a search for "lamp condoms or balloons" these are the OEM boots that fit over the bulb.
Regards,
Jim W
JWELK is offline
