YJ Lean - JeepForum.com
post #1 of 7 Old 03-26-2013, 07:03 PM Thread Starter
NMYJ
YJ Lean
So I got 93 yj with about a 1 inch lean on the driver side. (I weigh 200lbs) I bought it with a body lift. The front track bar is missing. Could that cause the lean?
Or could it be a worn leaf? Also what exactly does the track bar do anyway?
NMYJ is offline
post #2 of 7 Old 03-26-2013, 07:25 PM
Louie4
My jeep has the same lean but I think mine is due to the sagging/bent body mount on the rear drivers side. Leave the front track bar off and take the rear off if it's not already. They are there to keep the lateral movement of the axles in check but that's what the leaf springs do so they aren't really needed. They have more use for coil springs.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 7 Old 03-26-2013, 07:30 PM
Chrisnvegas
Chrisnvegas's Avatar
My CJ7 had a lean toward the drivers side after a number of years. I think it's because I was the only person in it most of the time. It bugged me so I rotated the springs and that took care of it.
Ban computer updates, auto-play video and music without real instruments.
Chrisnvegas is offline
post #4 of 7 Old 03-26-2013, 07:38 PM Thread Starter
NMYJ
Thanks Louie4. I like the profile pick by the way!
Thanks chrisnvegas I'm planing on putting some boomerang drop shackles on it this weekend so I might swap the right and left leafs.
NMYJ is offline
post #5 of 7 Old 03-26-2013, 08:39 PM
jokerchief462
Mine has. 1/2 " lean at the right rear. Only driver so that could be it. The springs is war I mean. If they are original stock they may be done. The track bar
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 7 Old 03-26-2013, 09:56 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
Just to be safe. Check all your shackle hanger mounts (where the spring goes to shackle hanger too). I had a drop about an inch and it turned out the shackle hanger broke, but stayed in place until I jacked the jeep up to fix the mount.
Thomas
-1987 YJ
Tompatt is offline
post #7 of 7 Old 03-26-2013, 11:47 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Push it over by hand.
Luck Favours The Prepared
Anticanman is offline
