Yj L shaped fuel line to filter - JeepForum.com
 1Likes
post #1 of 16 Old 09-23-2017, 07:12 PM Thread Starter
yj_kid_91
So I've searched around couldn't find anything. Dug on forums. Checked part numbers that are either discontinued or can't find anymore. So I tried searching molded fuel line. even was being specific on searches and added 5/16.
Couple months went by and I was on amazon and looked up fuel like. Just regular fuel like. Figured I'd re do it to the filter.
Then I tripped across it. I wanna say I paid all of 10 bucks for it. Might seem like alot to some but worth it. There's no way of getting around it but I digress.
It's a Briggs & Stratton fuel line same size the yjs use and its molded.all you gotta do it cut to desired size. I'll put the part number and what it looks like I just wanted to share for everyone out there.
15062152858491440490672_1506215350615.jpg   15062153643681752258455_1506215388056.jpg
yj_kid_91 is offline
post #2 of 16 Old 09-24-2017, 06:57 AM
JeepJJ
Thanks!
JeepJJ is offline
post #3 of 16 Old 09-24-2017, 08:22 AM
shaggyjim
shaggyjim's Avatar
Chrysler still stocks them. I just picked one up a month ago. I would guess that Briggs line is not pressure rated for 60 psi. Remember this will try and live one the pump side of the pressure feed right before a the slight restriction of the filter and see full pressure.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #4 of 16 Old 09-24-2017, 09:25 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Jim, do you remember what it cost? I bought mine from the dealer about 3 years ago. I think it was less than $6. And they had it in stock.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #5 of 16 Old 09-24-2017, 01:19 PM Thread Starter
yj_kid_91
They stock it for the yj? I've found a nylon L they had but I think they said it was a tj part
post #6 of 16 Old 09-24-2017, 01:21 PM Thread Starter
yj_kid_91
Forgot to mention it's braided like regular fuel line so I'd imagine it can withstand 60psi
post #7 of 16 Old 09-24-2017, 02:06 PM
shaggyjim
shaggyjim's Avatar
Ya it was like $30 but the local Chrysler dealer sucks....
It wasn't in stock they had to order it in so it took a day to get it, but yes sir it was a OEM rubber fuel elbow for the yj. It has the larger opening for the fuel filter side and the smaller side for the hard line side.
Lots of fuel line has braid in it, that alone is a poor indicator of the ability of a fuel line, that is sold to use in a gravity feed applications ability to withstand the fuel pump for long. In this case I need to "know" that the line will hold up or all I will be able to "imagine" is a YJ burning to the ground.
Jim...
post #8 of 16 Old 09-24-2017, 03:00 PM Thread Starter
yj_kid_91
That's a bad image. I'll have to call and ask them again. Do you remember the part number by any chance
post #9 of 16 Old 09-24-2017, 05:07 PM Thread Starter
yj_kid_91
Although 30 bucks it alot for a little piece. Ugh hate how it's a dealer item
post #10 of 16 Old 09-24-2017, 06:07 PM
shaggyjim
shaggyjim's Avatar
I did some digging and found this part number.. 53004014 Then I found a place selling them and they look just like the one I installed last month. Its still $23 for the little bugger....
https://www.factorychryslerparts.com.../53004014.html
https://www.factorychryslerparts.com...driveLine=7400
Jim...
post #11 of 16 Old 09-25-2017, 08:56 AM Thread Starter
yj_kid_91
Does it matter if I have a straight 6? Just lists 2.5l
post #12 of 16 Old 09-25-2017, 08:05 PM
shaggyjim
shaggyjim's Avatar
It's for the 4.0 as well.
Jim...
post #13 of 16 Old 09-25-2017, 09:57 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Cut the metal fuel line from the tank back 3 inches.
Flare the end of the metal fuel line.
Use a piece of FI 60 PSI rated fuel line long enough to make the connection without the bend.
NHfireLJ likes this.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #14 of 16 Old 09-26-2017, 09:15 AM Thread Starter
yj_kid_91
I would but I got stainless fuel lines other than the vent line to the charcoal canister. Actually anyone know where to get one if those lines?
post #15 of 16 Old 09-26-2017, 09:29 AM
NHfireLJ
NHfireLJ's Avatar
Those lines? Are you talking OEM hard fuel lines?
I have a full set, selling together...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
