Yj Jeep 4.8 with 4l60e. - JeepForum.com
post #1 of 8 Old 02-12-2013, 10:11 PM Thread Starter
Polrover
Im building my jeep but i have been told i need the cluster with the speedometer for the tranny to shift. Has anybody built one and not needed to use a speedometer? I already flashed the computer but dont know if i need a speedometer.
Polrover is offline
post #2 of 8 Old 02-12-2013, 10:14 PM
Ripper3494
you need the VSS on the back of the trans to run either into a pcm for an engine that typically had that trans, or into a seperate transmission control unit.
i run a 4l60e and it shifts just fine, i have no speedometer
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 8 Old 02-13-2013, 05:40 PM Thread Starter
Polrover
Sorry i did not reply faster im new to all this......i really thank you for replying.
Do i have to purchase an after market vss or does do i go ask at a junkyard for one?
I have not tested the jeep yet, what is the vss or where is it located,
I also dont really need a speedometer, is the pcm my computer or is that different?
Im using a 4.8 and a tranny with diff. From a suburban....i have the original harness and the
Computer has been flashed.
Thanks again.
Polrover is offline
post #4 of 8 Old 02-13-2013, 05:54 PM
Ripper3494
There are two wires coming from the pcm to the tail end of the trans (where the vss is located)
What t case are you running? Im guessing the 231C that came stock behind the 4l60e?
Ill take a picture of my vss tomorrow
Probably sent from under my broken heep
build thread:
RC vs BDS
post #5 of 8 Old 02-13-2013, 05:55 PM
Ripper3494
Chances are the vss is still in the Trans it's a pretty small unit
build thread:
RC vs BDS
post #6 of 8 Old 02-13-2013, 06:12 PM Thread Starter
Polrover
Yes you are correct im using the stock t case that came with it.
Thanks i would really appreciate those photos.
Is the pcm the same as my ecm?
Also how can i put a picture of my jeep like you did next to my replies?
Polrover is offline
post #7 of 8 Old 02-13-2013, 06:21 PM
Ripper3494
Yep the ecm and pcm are technically the same.
And to get the picture you have to be a paying supporter of the forum (it's worth it if you purchase stuff from vendors on here) I've saved more money with member discounts than I spent on the membership
build thread:
RC vs BDS
post #8 of 8 Old 02-13-2013, 07:01 PM
jbolty
jbolty's Avatar
http://www.jeepforum.com/forum/f6/ne...forum-1426268/
jbolty is offline
