YJ Ignition Help - JeepForum.com
post #1 of 9 Old 01-28-2013, 03:42 PM Thread Starter
RCYJ
1987 YJ Wrangler
YJ Ignition Help
Hello All,
I have a 87 YJ 4.2L, when I turn the key at on poistion (not yet to start the jeep), no power at all, no electronics. So the Jeep won't even start. Battery is good and tested the solenoid and it works. Is there a fuse that I have to check in the middle somewhere or is the problem in the steering column area. Thanks for the help.
RCYJ is offline
post #2 of 9 Old 01-28-2013, 03:49 PM
YJ4LIFE
Originally Posted by RCYJ View Post
Hello All,
might be an inline linkable fuse under the battery. happend to me a few months ago when my choke wire shorted out on the valve cover
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #3 of 9 Old 01-28-2013, 04:19 PM
jozeppi
im haveing the same problem with mine the starter and the battery are brand new the alt i put in about 3 years ago its a 136 amp so i have no idea what it is
jozeppi is offline
post #4 of 9 Old 01-28-2013, 04:20 PM
jozeppi
and plus it shut off while i was driving it
jozeppi is offline
post #5 of 9 Old 01-28-2013, 04:27 PM Thread Starter
RCYJ
1987 YJ Wrangler
Is this wire connected to the battery or connected to the solenoid. There's three wires connected to terminal of the solenoid along with the positive battery cable. Thanks.
RCYJ is offline
post #6 of 9 Old 01-28-2013, 04:33 PM Thread Starter
RCYJ
1987 YJ Wrangler
Mine started fine and as I was warming up the Jeep it just shut off. That was the last time I had electronics with the ignition on. We both definitely have some kind of a short somewhere.
RCYJ is offline
post #7 of 9 Old 01-28-2013, 05:05 PM
jozeppi
I'm gonna try changing the relays under the hood lets hope that does it cuz last time I paid to tow it to the shop and when he got in it in the morning and tried it guess what it started all day so I took it back anemone problems till now go figure
jozeppi is offline
post #8 of 9 Old 01-28-2013, 05:16 PM
Que89YJ
Jozeppi you need to post up to your own post. Your electronics are light years different from RC and what will fix his is not even close to yours. RC, yes the fuseable links are the wires that attach to the solinoid.
Que89YJ is offline
post #9 of 9 Old 02-02-2013, 06:35 PM Thread Starter
RCYJ
1987 YJ Wrangler
Fixed it! The solenoid was not mounted tight enough to the wall so there was a bad ground. I think it might have damaged the solenoid so after I replaced it the Jeep started. Thanks for all the help.
RCYJ is offline
