YJ Idle problem - JeepForum.com
post #1 of 3 Old 06-22-2002, 12:40 PM Thread Starter
YJ Dude
YJ Idle problem
Hello All. I have a problem with my 94 YJ with the 2.5L that has me baffled! The problem is that it idles anywhere from 1600 RPM – 2600 RPM. Here is a list of the components that I have changed so far: AIS Motor, Throttle Positioning Sensor, Oxygen Sensor, Distributor cap, Rotor, Plugs, Plug wires. I have also removed the Throttle Body and cleaned it thoroughly. It now runs very very well but still idles way too fast. I have also checked for Vacuum leaks but can’t find any. Throttle linkage is working fine also. Does anyone have any suggestions?? Thanks much! John
94 YJ, 2.5, 4" ProComp Lift, 33's,
EZ Locker, Warn M8000 winch, Home made tire/jack carrier, nurf bars.
YJ Dude is offline
post #2 of 3 Old 06-24-2002, 01:32 PM
SnowMan
I have the same engine, but the opposite problem. Mine idles to low and jumps, but in my dwelving on this problem I was told that a high RPM is usually a sign of a vacuum leak. If you haven't already I would zip tie all the vac connections, it might help. Just a suggestion
Is that you John Wayne, is this me!
SnowMan is offline
post #3 of 3 Old 06-24-2002, 08:20 PM
my litte red yj
hey snow man i also have the same low idle as you as soon as my jeep warms up it is better but at a cold start rough!! i replaced tps,ais,dist,cat,muffler,plug's,cap,rotor the next thing i am replacing is there is a ambuent temp sensor on left side near fire wall
my litte red yj is offline
problem with idle black71gp TJ Wrangler Technical Forum 9 12-03-2008 07:55 AM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 08:50 PM
tj idle problem scrappy TJ Wrangler Technical Forum 2 04-04-2003 10:23 AM
97 4cy idle problem Wally TJ Wrangler Technical Forum 4 04-03-2003 07:38 AM
Idle Problem mikeyhaken TJ Wrangler Technical Forum 1 03-03-2002 11:02 PM
