YJ Homemade Highline - JeepForum.com
post #1 of 28 Old 09-14-2009, 10:38 PM Thread Starter
OVERLAND_YJ
in another thread i have been asked for info on hom i did my highline, i had another thread on a different old forum but seems it has been moved/deleted. so i'll write up here a brief description, i will let the pics do most of the talking. if you have questions feel free to ask.
the start, 34" LBT's with just a 1" BL and 5/8 boomerangs, not much room for flex
measure and mark, tried 3/1/4" first but 3" turned out to be the magic number
dissasembly
new holes in fenders where they mount to grill, on the back end where they mount to the firewall i had to drill new holes 3" down from the factory holes. i have seen nicer ways of doing the front of the fenders since i did mine but i just 'massaged' them with a hammer to make them fit
one raised...big difference
the begining of the 'massaging' to make the front fit. this was later smoothed out and then filled with some body filler to get a not so close to factory finish
marking the hood 3" up, measure twice cut once
hood cut and i used some plastic edging to cover the cut edge
fender after undercoating them and re-painting the inside of the inners
one side bolted up
painted undercoat where rocker guards would eventually go to disguise the 3" gap at rear of the fender
both bolted up
alot more room for the 34's now
finished
i have had several people look at the front of my jeep and say "is ther something different?"
all this in less than a day. while i had it all apart i cleaned up the firewall and painted it as well. once i mounted the new sliders they covered that 3" gap at the bottom of the rear of the fender.
any questions?
Dont forget to wave, OVERLAND...
OVERLAND_YJ is offline
post #2 of 28 Old 09-14-2009, 10:43 PM
Speed911
Holy winch plate batman!
Looks great though, I'm a fan of highlined fenders, and these look superb, especially for a homebrew. Great work!
-Dane
Speed911 is offline
post #3 of 28 Old 09-14-2009, 10:49 PM Thread Starter
OVERLAND_YJ
that is a 'superwinch' winch plate. perfect for the 8274, it was old stock, dont even know if you can find them any more.
then i added the Xenon flat flares
post #4 of 28 Old 09-14-2009, 10:58 PM
88heep
nice work!
88heep is offline
post #5 of 28 Old 09-14-2009, 10:58 PM
moonshinefuel
Wow, . I like it, A LOT.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #6 of 28 Old 09-14-2009, 11:41 PM
KRenegade
I have been tossing this idea back and forth. Are you running into any clearence problems with your rear tires?
[QUOTE=rustywrangler;8778661][SIZE="3"][B]Well that was fun. Anyone else want to dance with the ban stick????? QUOTE]
KRenegade is offline
post #7 of 28 Old 09-15-2009, 01:54 AM Thread Starter
OVERLAND_YJ
i will post up pics of what i did in the rear, i cut that out 1" and also put the flat Xenon flares on and ran like that with the 34's for a while but at full stuff they did rub a bit. so i put in a 4.5" RE lift, no i dont have rear clearence issues now and now i run 37" IROKS.
post #8 of 28 Old 09-15-2009, 11:04 AM
H3RTCH
Live Free or Die.
H3RTCH's Avatar
Do you have any pics of this at full stuff?
Brandon
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline
post #9 of 28 Old 09-15-2009, 11:14 AM
fireshadow
Looks real good
1988 Jeep Wrangler, home made posi lock, team rush upgrade, motorcraft 2100 carb, warn m8000 winch, np231c front yoke, rc 2.5" lift, 1" lift shackles
Even my motorcycle has a square headlight(1984 Honda Saber)!!!
fireshadow is offline
post #10 of 28 Old 09-15-2009, 11:23 AM
Hurley91
That looks real good man
Hurley91 is offline
post #11 of 28 Old 09-15-2009, 01:47 PM Thread Starter
OVERLAND_YJ
so onto the rear, cut out about an inch all the way around the wheel well, less at the front and more at the rear. didnt want to cut into the seem that holds the inner wheel well onto the tub so thats about as much as you can take off on the top and front of the well. also wanted to leave enough steel to bolt the flares to since i still wanted to be able to use a flare i cvan buy off the shelf for less than a million dollars when i break em.
before...
stock flare and inner fender off
taping for marking
cut at the front
cut at the rear
after cutting
tire on, no flare
factory flare that had been trimmed
comparison shot
xenon flare
gratuitus girlfriends legs shot
before the 4.5" RE lift
after 4.5" RE lift
so i guess i've gotten a bit off topic of the highline. but it is a progression that was started with the highline and finally finished with trimming the rears and then the lift to get the clearance i needed.
these pics are all with the 34's, it now has 37"s. sure she sits high but she is still SUA. i like trying to keep the COG low. i know i could cut more sheet metal and get it lower. i am now looking at taking the 1" BL out and maybe a little more trimming.
post #12 of 28 Old 09-15-2009, 01:59 PM Thread Starter
OVERLAND_YJ
this is how she sits today. 37" IROKS, you can see the sliders have covered the 3" gap left at the bottom of the front fender from the highline. with the 4.5" RE lift i also got 4" extended bump stops so i put them in to eliminate any body/tire conflict issues. have the same bumpstops in the rear as well.
new front shock hoops, bilsteins and you can see the extended bumpstops. dont pay attention to the hi-tech sway bar hold up wire....
as she sits now
post #13 of 28 Old 09-15-2009, 04:09 PM
tomesd
Looks awesome!
1995 Wrangler SE Sport
[ ].[____].
l__L_-[]lllllll[]-_
()_) ()_)=@=)_)
tomesd is offline
post #14 of 28 Old 09-15-2009, 05:16 PM
deerslayer123
Very clean mod. looks great
deerslayer123 is offline
post #15 of 28 Old 09-15-2009, 06:05 PM
GRN_BEAST95
dude ur jeep went from sweet jeep to totally bad *** jeep quickly. i like how it looks. very nice jeep man
1995 YJ emerald green
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Green Jeep member 153
Originally Posted by yellojeeper View Post
Guam. I spent a week there one night.
GRN_BEAST95 is offline
Another DIY Highline tommaho TJ Wrangler Technical Forum 52 12-01-2010 11:37 PM
New SL or highline kit? Schwalby TJ Wrangler Technical Forum 4 09-30-2008 01:23 PM
My homemade highline/Aussie lift dmoffat TJ Wrangler Technical Forum 7 05-06-2008 08:47 PM
AEV Highline Kit Supertau TJ Wrangler Technical Forum 34 01-05-2008 04:25 PM
AEV Highline Kit 172heavy TJ Wrangler Technical Forum 2 04-02-2007 04:38 PM
