Yj high oil pressure? - JeepForum.com
post #1 of 15 Old 02-14-2013, 04:16 AM Thread Starter
grizzlycb
My 2.5 has always had its oil pressure a little on the high side. I'm not sure why and I keep changing the air filter and it has spots of oil on it. Any body else with this issue before ?
grizzlycb is offline
post #2 of 15 Old 02-14-2013, 04:39 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Define "a little on the high side" please.
Oil in the air filter is not uncommon with older YJs.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 15 Old 02-14-2013, 05:21 AM
dswi
Is the gage electrical or mechanical...Sending unit?
Character is Who You Are When Nobody Is Looking!!
Darrin
dswi is offline
post #4 of 15 Old 02-14-2013, 06:35 AM Thread Starter
grizzlycb
Well it runs on the 60 at about 2100rmps in fourth, it's normal at a idle. I haven't been too concerned about it in my 95 Dakota it always ran a little high also. Main thing I was concerned about was oil on the air filter. I wasn't sure if it was common or not. This is my first jeep. I've owned it a little over a year now and have done some maint on it(distributor, crankshaft sensor some simple fixes like that. )
post #5 of 15 Old 02-14-2013, 09:04 AM
jokerchief462
Mine is the same fresh overhaul. Not an issue. The only bad oil pressure is zero.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 15 Old 02-14-2013, 09:26 AM
ROTTEN
X2
My psi at cold temps is 70 at 2000rpms
Warms up and stays around 50 ish
Idle around 40
My old xj ran 18 on a hot day
My older xj ran 12 but I'm betting it was sludged up and I didn't take the greatest care of it. At 198k it developed a bad o ring gas leak and was sent to junkyard heaven...
I'm new
ROTTEN is offline
post #7 of 15 Old 02-14-2013, 11:00 AM
Old4X
1990 CJ7
These engines have high pressure pop-off valves, you can't get damage from high oil pressure.
If your gauge reads something too high, it is a bad sender, gauge, or electrical problem.
Oil getting into the air filter is a maintenance issue, you need to clean out the crank case breather system, including pulling the valve cover and cleaning out the baffles.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 15 Old 02-14-2013, 12:09 PM
soonermatt
I bet it is your sending unit about to go out. I had a similar problem until it was reading extremely high. Then I developed a leak that got progressively worse. When I finally dug in I discovered the sending unit was bad and oil was leaking through it.
I replace the sending unit and my pressure went back to normal and the leak was fixed.
If it gets higher and starts leaking you might look at sending unit.
soonermatt is offline
post #9 of 15 Old 02-14-2013, 04:45 PM Thread Starter
grizzlycb
It might be my sending unit It looks like I might have a small leak. I can't tell from where I had a bad oil cap a few months ago and it's been to cold to clean it off( I work 5pm to 5am) would the leak be on the drivers side of the engine? I don't have any drops or leaks under my jeep when I park it just some on the side of the block( I can't tell if its new or not though.
post #10 of 15 Old 02-14-2013, 04:48 PM
zombiechief
That's where mine sits too...
Treat every situation like a dog. If you can't eat it or play with it pee on it and walk away.
zombiechief is offline
post #11 of 15 Old 02-14-2013, 08:38 PM
Carlos14
Mine sat all the way up as high as it reads until one day I looked at it and my stomach dropped noticing that it was on zero. I immediately check that I had oil and turns out the sensor was bad. $38 later its good as new, sitting just as high as your currently.
Luck Favours The Prepared
Carlos14 is offline
post #12 of 15 Old 02-14-2013, 09:43 PM
sxysouthtx
X2 on that. Mine would fluctuate through acceleration. 0-80 PSI. Talk about pure panic. Replaced it on the cheap. All better.
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #13 of 15 Old 02-14-2013, 10:07 PM Thread Starter
grizzlycb
Is it a pretty quick find as fix?
post #14 of 15 Old 02-14-2013, 10:25 PM
ROTTEN
Yes. I believe its near the oil filter. I haven't changed the one on the 2.5 but I did on the 4.0 3x
I used a crescent wrench.
Unplug connector
Unscrew unit
Screw it back in. Tighten but not super tight
Plug in connector
Start it up.
Mine leaked oil through the connector
I'm new
ROTTEN is offline
post #15 of 15 Old 02-14-2013, 10:28 PM
Carlos14
it is above the area of the oil filter, a little black cylinder looking thing. If i recall correctly, I dont remember it taking longer than 15 minutes
Carlos14 is offline
